engine removal tips
  • Rootie524
    • Feb 2010
    • 543
    engine removal tips
    whats the easiest way to pull an engine out of a nbody. i want to leave the trans in but there seems to be little room to get the engine on an angle to yank it out. wondering if anyone has some tips that would hlep.
    • 9191
    Tie off the hood somewhere so that it stays vertical or just take off the hood completely. Easiest way I've done it in the past.
    Droid via Tapatalk
    • Rootie524
      • Feb 2010
      • 543
      the hoods the least of my worries. im talking like do i need to unbolt some trans mounts to be able to move it or can i leave the trans compltely bolted down and work around it. because the engine has to come off the trans a good few inches before it can be pulled up.
        • 9191
        Besides any trans mounts that bolt to the engine, I have never loosened or taken off any trans mounts when pulling the engine. L-bodies should be similar to N-bodies as far as engine bays go. I know it gets really tight on the passenger side trying to get it past the fenderwell, it you can do it.
        First time a pulled the engine (cam swap into original 3100)
        Next time I pulled the engine (3400 swap)
        • bob442
          Show Me Your KITS!
          • Nov 2008
          • 1305
          you can get that back 18MM with a few extensions from the passenger side fenderwell, the AC compressor should slide down out of the way, check that everything is undone, and clear about 3 or 4 times, i alsmost always forget something. except the last time i did it. and if it looks like it could accidentally break with removal, just remove it. as in the rear O2 sensor. pulling off the alternator will help to, and put a jackstand under the transmission to keep it level while you pull out the motor, otherwise it will lean over and take up that little bit of space on ther passenger side.
          The braket on the tranny to the motor on the passenger is best to remove completely, IDK if that was asked but its answered
            Live life 3.7mi at a time
            • 4555
            Yup, after taking off engine mounts, roll the engine forward and grab off the alt in a fwd motor pull.
