3t40 and 3.1 LH0 onto a early 99 malibu L82
  • S12_200zx
    • May 2025
    • 10
    Hello folks - I have a 99 Malibu and a 91 Lumina, with the 99 having that dreaded camshaft death due to intake gasket leak. I would like to see if I could swap the 3T40 and the 3.1 LHO from the Lumina over to the 99 Malibu..
    Will I need custom half shafts or can I source from a different GM truck/car?
    Second Idea - Could the L82 swap into the 91 Lumina without significant re-work (I might rebuild the L82 over a weekend)?
    • 13531
    Don't. Thats my thoughts on this. Rebuild an L82 with a broken cam over a weekend is not happening. If the cam broke, the cam bearing seized, and another bearing might not work at all. Just a waste of time considering the cost of 60V6s in general. Did the malibu trans blow up? Why swap it out? I would not put a 3 speed into anything unless it was already a 3 speed.
    Putting a 3100 or 3400 into a 91 lumina will work but you will have to change the tune for it among other things. Fuel rail fittings, engine mounts, etc.
    • S12_200zx
      • May 2025
      • 10
      Acquired the 91 Lumina and 99 Malibu as salvage, paid nothing. Lumina needs fuel pump and an issue w/ reverse whereas the 99 Malibu has that trashed engine and a good auto transmission. If its a waste of time putting the 4T40-E​ into the Lumina, im all ears. The Lumina engine is good and I suppose I can rebuild the Lumina auto transmission sometime later.
        • 13531
        You will have to swap the wiring harness for the 4T40-E, and then tune the computer to disregard all the missing parts the engine doesn't have. Custom axles maybe, not sure. I would put the 3.1 into the alero if that was what I had to work with. Id buy a 3100 or 3400 or maybe a 3500 depending on prices, if it was in the budget. Less hassle, better results.
