Best candidate for the 3400? What would you put it in?
  • luckydog
    • Mar 2006
    • 2
    I may have the opportunity of inheriting my mom's 1998 Olds Minivan, with a 3400. I love the power of that motor, it scoots even in a heavy van. I'd love to put it in a small gm fwd car. The van is rusty already and it has alot of mi, so I wouldn't be dismantling a good vehicle if I used the motor as a donor.
    If I did a swap, I would have to have a 5 sp car. I like the looks of the grand prix the most, but it's pretty hard to find 5 sp. prix's.
    So what would you guys put this motor in? Beretta? Grand am? Grand Prix?
    Edit: I just had a thought. In order for this motor to work with a 5sp trans, I would have to have a 5sp pcm. Does a 5sp 3400 pcm even exist?
    • 13531
    If its gotta be a FWD 5 speed...cavalier/sunbird hands down. Lightest vehicle, especially the 87. Beretta wouldn't be bad. Grand am wont have a 5 speed setup unless its a 4 banger which is more work. Grand prix is heavy (what I have).
    87-94 cavalier would be a good swap. v6z24.com has a quite a few swap owners, and domesticcrew.com is dedicated to the 3rd gen 60V6 swap into a J body.
    • Doubt_Incarnate
      I still watch ROBOTECH!
      • Jan 2005
      • 1130
      motorcycle... J/K.
      a fiero, a j-body. i'd put one in mine if i had one. but i don't and my fab skills are limited to grilled cheese sandwiches. some people swap them into MG's or other brit cars.
      • korbendallas68
        • 3400swap.com •
        • 553
        Depends on what you like. I prefer 92-95 Grand Am GT bodies (N-Bodies), so that was the obvious choice for me.
        On a side note,
        You can also take 5-speeds from other cars (Beretta, cavi, ect...) and install them into a GA. The only thing that you would need is the interior pieces for the GA's shifter console (4-banger).
        1995 Grand Am GT
        3400 V6 / 4T60-E / Engine Swap
        3400 Engine Swap Guide Version 2.5 is Available!
        www.3400swap.com
        • Doubt_Incarnate
          • Jan 2005
          • 1130
          i almost forgot the coolest one, especialy with summer on the way,
          SAND RAIL BUGGY! it weighs like 1500lbs, with 185hp and a 5speed mounted in the rear. how awesomwe would that be? especialy since you could do a little off roading.
          • jp_grasshopper_007
            Power Level:1,000,000
            • Mar 2006
            • 120
            Put it in a 72' nova that would be badass!!!!!!
            because I\'m not Canadian
            • luckydog
              • Mar 2006
              • 2
              Hmm, I like the 92-95 GA's. But would a 5 sp. from a different car be compatible with the auto 3400 pcm from the van?
              • korbendallas68
                • 3400swap.com •
                • 553
                You don't use the ECU (PCM) from the Van. You would use a older 3100 or 3.1 ECU. There are many people that could answer this better too.
                Check out my site: www.3400swap.com and download the guide to get a little more info.
                Also, the a 5-speed has been swapped into many Beretta's (Which are almost exactly the same as the GA's). If I can get a place with a garage soon, I'm pulling it off and writing another guide, unless someone else beats me. :P
                1995 Grand Am GT
                www.3400swap.com
                • RednBlack
                  Wood Hippie
                  • Mar 2004
                  • 2795
                  Uh, put in an 87 Cavy Wagon.
                    • Mar 2006
                    • 120
                    With 20"s that would be a sick getto sleeper.
                    • Manitcor
                      • 573
                      Fiero, 5-speed
                      RWD + proper weight distrubution + light as hell
                      1995 Monte Carlo LS
                      3400 SFI 60v6
                      • LeftVentricle
                        Right aorta
                        • Oct 2005
                        • 506
                        Pardon?
                        Quoted for truth. THAT'S a hell of a sleeper.
                        20's wouldn't even fit under an old Cavalier.
                          • Mar 2006
                          • 120
                          yes they would
                            • Mar 2006
                            • 120
                            72' nova.............
                            there's a guy wanting to put a 3800 in 1
                            • RednBlack
                              Wood Hippie
                              • Mar 2004
                              • 2795
                              With fabrication, all things are possible. And I meant to say 87 Celebrity Wagon. My bad..
