3400 Swap PCM?! Fuel Adjustments? Help!
  • Impetuousracer
    • 34
    Have 98 Malibu. I did 3400 swap. Everything is peachy keen. However, I am still using the 3100 PCM. The 3400 PCM looks like it will plug in. Will this work, or will my cluster light up like a X-Mas Tree? I would like to have the better fuel curve and such. I ordered a Pro-M Maf for a 99 Grand AM. However it doesnt work. (Idles fine, no check light, partial throttle ok, full throttle feels like I am hitting speed governor?) Pro-M said I need it calibrated for the Malibu. ASE is no longer around. Does anyone offer tuning for newer GM PCM? Friends have tuned Honda's with S-AFC and such, and get huge results. I feel that I could get a lot more with better tuning, which is almost impossible to do with this PCM. ANyone have any other suggestions
    • 13534
    You could get the OBD2 scan tool and try to adjust the MAF so that the computer feedback shows it running closer to spec. Thats the best I can think of unless someone can actually program the ECM for you custom with the car.
    I don't know about using the ECM, if it will work with your trans or not. I assume you are talking about using a 99 grand am computer.
