95 GP 3.1L To 3.8L
  • chrislj2
    1995 Pontiac GrandPrix SE
    • Jul 2006
    • 3
    95 GP 3.1L To 3.8L
    I I have A 1995 grand prix se and was wundering if anyone has swaped a 3.1l to a 3.8l. Could it be done is there kits to do so.
    thanks
    Chris
    1995 pontiac Grand Prix Se
    • 13534
    Wrong site for a 3800 swap.
    • chrislj2
      • Jul 2006
      • 3
      ok so how about puting a 3400 top end on the 3100
        • 13534
        Search, lots of topics on this. You need a 3400 lower and upper intake. Watch the rocker arm to lower intake clearances (might have to grind some off the lower intake).
        • Calvin
          3.77 1st gear sucks...
          • Feb 2006
          • 61
          Alternatively you could get the 3400 heads with the roller style rockers to complement the upper and lower intakes and then you would have big valves, big intake, roller rockers, and no worries about clearances. I suppose you could even throw a whole 3400 in and be done with it. The 3400 will use your old acc brackets, the only thing to watch out for is that you use the year cam sensor that the block is. If you use a 00-02 3400 you will have to get a new downpipe made up, but mine cost me $120 out the door as part of a whole cat-forward exhaust upgrade on a 89 GP.
            or keep your 95 3100 exhaust manifolds and downpipe, no mods nessasary. The 3400 style rear flows better though.
            95 heads you might need to clearance teh LIM. 94-95 didn't have roller rockers and they will hit. Some 95 had rollers, but its rare. But if you swap heads, no problem.
            • bu01
              • Apr 2004
              • 91
              • chrislj2
                • Jul 2006
                • 3
                how heard is it to swap a whole 3400 engine. like 2000 or so with a manual trans. is converting the auto to a manual worth it. I know it wood make the car more fun to drive but im also 17 and cant spend $2000 or more on it right know. and i was also wondering if the 3400 headers i see would work i the 95 3100 engine. id like to do a full 2 1/2 exhuast systom but cant find headers
