Dand Rail pics- From air cooled VW to 3.4 Turbo
  • Second Skin Rep
    • Jul 2006
    • 37
    took a little while to do, but here is my cardomain page that runs through the sand rail changes
    Let me know what you guys think!
  • Ortie666
    • Jul 2005
    • 340
    What did u do with the old webers?? what size are they?? were they IDF's or IDAwsomes??
    Six-t-Six Motorsports
    2.8L Chevette Roadcar
    3.2L Acadian Racecar
    • Second Skin Rep
      • Jul 2006
      • 37
      they we delortos. 45's sold them to a guy up the streeet
      ANT
        • 13532
        I bet that thing is pretty quick I saw something like that on the road a couple days ago, though I think it had a VW air cooled setup in the back from what I could tell.
        • Stewart G. Griffin
          • Aug 2006
          • 33
          What i want to know is, did you use a commercially available turbo kit or did you fabricate your own?
          b) How did you handle the fuel pump situation?
          • Second Skin Rep
            • Jul 2006
            • 37
            The shop that does the work is Poor Boys Sand Cars of Phoenix AZ.
            They Fabrictaed it all. Not a bolt on package or anything.
            Not sure about the fuel pump. What exactly is the fuel pump Situation?
            ANT
              • Aug 2006
              • 33
              1) How much HP? How much total cost?
              2) RE: fuel pump situation:
              The 3.4 has no mechanical fuel pump provision?
              • Second Skin Rep
                • Jul 2006
                • 37
                According to the shop I am somewhere between 250 and 300 hp on 110 octane. pretty big gap though. I'll have to get it dyno'd to find out for sure.
                It only weighs about 1200 lbs with the engine so she is very fast.
                As far as I know they used and electic fuel pump but thats as far as it goes. I don;t know anything else about it. I will be dropping it off tomorrow to get tuned up a bit.
                For some reason any time I turn to the right while on the gas she starts to sputter out. Second gear too. When I am gunning it from first to second the higher RPMs in 2nd start to sputter out. like I am losing gas, or like the gas line has air bubbles evenly spaced out.
                they can't figure it out...
                  • Aug 2006
                  • 33
                  Total cost?
                  • Second Skin Rep
                    • Jul 2006
                    • 37
                    Total cost?
                    Total engine package with custom turbo, upgraded suspension with new motor mount bracing and paint.
                    $6500
                      • Aug 2006
                      • 33
                      Not bad.
                      Who is the vendor?
                      • Second Skin Rep
                        • Jul 2006
                        • 37
                        Not bad.
                        Who is the vendor?
                        Poor boys sand cars in Phoenix AZ
                        They built the engine.
                        ONly problem now is that it sputtins in the high RMPS or when I throttle to the right...
                        they are trying to fix that one now.
                          • Aug 2006
                          • 33
                          How much total HP? Torque?
                          The sputtering means you're running lean at those RPM's and while turning right. I will read up more on this and get back 2 U if i get a chance. But i don't got no time.
                          • Second Skin Rep
                            • Jul 2006
                            • 37
                            They are telling me it is around 250 hp. maybe more but at least 250. Not sure onthe torque.
                            They tried to adjust the jets. To richen them up. they messed with the float level.
                            Can't seem to figure it out no matter waht jets of float level they set it at..
                            • Canyonero
                              Plays with Volvos now.
                              • Sep 2006
                              • 1112
                              Sounds like you need fuel injection!
