Some Vid Clips of A Wierd Humming Noise
  • 94GPGTP
    95 Grand Prix GTP
    • Apr 2007
    • 593
    Question : Some Vid Clips of A Wierd Humming Noise
    OK well some background.. This is on my 1996 Pontiac Grand Prix SE 3100..
    Brand New Rebuilt Engine And Transmission, New Wheel Bearings all around, Drilled and Slotted Rotors with Ceramic pads, New Tires, New tierods and balljoints....
    Bumped tire size from 225/60/16 to 245/50/16
    Well when i am going straight there is a wierd hum nosie.. can feel a little vibration in the floor pan.. but going on a slight right is gets louder but turning slightly left it gets real quite but not as loud as going straight.. here is 2 videos of the noise.. Oh it almost sounds like a Mud tire on a lifted truck.
    Let me know what you think.. It has been happening for the past month but the car sits for at least 2 weeks..
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    Drilled/Slotted Rotors
    White
    3" Magnaflow Catback
    90 Pontiac Turbo Grand Prix
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    230,000 mile Getrag 282
    Emissions Deleted
    Brand new Engine 1,000 Miles
    Fully Custom Built car
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    Sounds like a shifted belted.
    • 94GPGTP
      95 Grand Prix GTP
      • Apr 2007
      • 593
      Tires are Firece UHP 245/50/16..
      Heres a link http://www.kellytires.com/kellytires...ea=Performance
      When i get some time i will try to get the tire off and rub my hand over it to feel for any broken bands.. But i think your right thats what it could be..
      Robert
      New Rebuilt 3100
      New Rebuilt 4T60-E
      Exhaust
      White
      5 Speed Swapped
      127,000
      Spec Stage 3 Clutch
      Emissions Deleted
        Too wide of tire rubbing?
        Wheel bearings tightend down enough for proper preload?
        • 94GPGTP
          95 Grand Prix GTP
          • Apr 2007
          • 593
          Have checked for rubbing there is none of that going on..
          I'm pretty sure that i have torqued them down to spec. But when i pull the wheel off i will check torque on them again.. I drove the car from 0-1,500 mileswith everything new from chicago to san antonio with no noises... But will check both when tire comes off..
          Appreciate the HELP guys.. Thanks so far
          Robert
          New Rebuilt 3100
          New Rebuilt 4T60-E
          Exhaust
          White
          5 Speed Swapped
          127,000
          Spec Stage 3 Clutch
          Emissions Deleted
          • 1988GTU
            LB62LHObbqftmfw
            • Nov 2005
            • 2475
            Swap with the rear tires and see if the sound/feel follows.
            • torq455
              If I only had money!!!
              • 1615
              if you have broken belts you'd have a shaking vibration. gererally, if the noise is louder when turning one direction and quieter turning the other direction, it's a bad wheel bearing on the side that's louder since it's take the load of the car. it is possible to have a defective new part.
              Andy
              fastest 1/8: 10.19@ 67.17
              fastest 1/4: 16.16@ 82.70
              • 94GPGTP
                95 Grand Prix GTP
                • Apr 2007
                • 593
                if i turn hard to the left it makes noise just like when i turn right.. took off the wheel today and inspected the tire and doesnt look bad.. Unfortunaly i didnt have the correct size socket for the axle nut and couldnt check that but when i had the wheel on i checked for play on the wheel bearing and there wasnt any..
                Robert
                New Rebuilt 3100
                New Rebuilt 4T60-E
                Exhaust
                White
                5 Speed Swapped
                127,000
                Spec Stage 3 Clutch
                Emissions Deleted
                • 1988GTU
                  LB62LHObbqftmfw
                  • Nov 2005
                  • 2475
                  Any updates? Find out the root problem yet?
                  • torq455
                    • 1615
                    put the car in the air, start it up and through it in drive. with the wheels spinning, look at the tires. looking at a stationary tires tread won't tell you anything about that noise.
                    Andy
                    • 94GPGTP
                      95 Grand Prix GTP
                      • Apr 2007
                      • 593
                      ahhh no not yet... I just let the car sit right now cuz i got my 3" system on my GTP so i drive the GTP a little more no since the exhaust...I actually swapped cars b/c i am going to put a tranny cooler on the GTP and change the fluid.. So here is something that is wierd.. I am driving the car no and the noise is LOUDER and more aggressive.. I am really thinking that its the wheel bearing...
                      Actually i lied i have checked torque on the cv nut and it it tight as can be.. i turned t a hair more to make sure it is tight..
                      Robert
                      New Rebuilt 3100
                      New Rebuilt 4T60-E
                      Exhaust
                      White
                      5 Speed Swapped
                      127,000
                      Spec Stage 3 Clutch
                      Emissions Deleted
                      • 94GPGTP
                        95 Grand Prix GTP
                        • Apr 2007
                        • 593
                        I dont know what you mean...
                        Robert
                        New Rebuilt 3100
                        New Rebuilt 4T60-E
                        Exhaust
                        White
                        5 Speed Swapped
                        127,000
                        Spec Stage 3 Clutch
                        Emissions Deleted
                        • torq455
                          • 1615
                          haha, i can see what you mean. i meant you can't see if the tire is distorted by taking it off and looking at it. you need to see it in motion. a wheel bearing is a constant humming. slow speeds ie. 5-10 mph you won't hear much if anything. the faster you go the worse it gets. you have a whomp whomp sound which tells me a tire, especially in the vid.
                          Andy
                          • 94GPGTP
                            95 Grand Prix GTP
                            • Apr 2007
                            • 593
                            right thats what im getting..but i have rotated the tires from front to back and back to front and still getting the same noise..
                            Robert
                            New Rebuilt 3100
                            New Rebuilt 4T60-E
                            Exhaust
                            White
                            5 Speed Swapped
                            127,000
                            Spec Stage 3 Clutch
                            Emissions Deleted
                            • torq455
                              • 1615
                              ya, you still have the same tires on the car. sometimes it's hard to tell where the noise is coming from. hell, put the spare on and see what happens.
                              Andy
