transverse monoleaf delete
  • grandprixgtp_93
    • Feb 2010
    • 75
    ive heard that you can get rid of the horrid monoleaf spring for adjustable coilovers? anyone know if the make a kit for this or if i can go buy a set of kyb adjustables for the car all the way around and put them in with some modification and get rid of my monoleaf i do some autocross racing and the monoleaf just doesnt satisfy also does anyone know where i could get a rear strut and front strut bar to add in to this mix to help stiffen up the car i found a universal fit 2 point b piller bar that my buddy had in his maxima that fit with some minor modification that helped with the body roll a little bit im just looking to be able to attack coners and and scream down windy roads with no problems i already have the engine built up nicely just need to upgrade the suspension now
    • 13531
    Just buy my car for 3k and have everything you need for autocross.
      Well one thing that would make things easier is attacking some punctuation. Cutlass convertibles had front strut tower braces stock. I believe a member on here that goes by the name Aweb makes rear braces. KYB makes adjustable now? The last place I knew where to get adjustable struts was Koni, and they stopped making them long ago. Twindualcam.com and Fast Forward Performance used to sell coil over kits, but both are long gone.
      • RedZMonte
        • Feb 2004
        • 1378
        if you want it to handle better without braking the bank on coilover setup i would do:
        * KYB struts
        * Front and Rear strut bars (few people make them)
        * Addco Rear swaybar w/ Monte Carlo Z34 brackets
        * Polly control arm insterts (W-body.com has the wright up) and Polly Swaybar bushings
        * Trailing arms (ZZPerformance, BMR, Ect.... Dorman makes a OE replacement that is Tubular)
        * 1997+ Grand Prix GTP lateral links (tubular rather then stamped steel)
        * Suspetion Techniques front lowering springs
        * Replacement Mono Leaf (can someone help me remember who makes the lowering leaf repalcement?
        * Better Tires... I ran a 235-55-16 that handled MUCH better then the stock 225-60-16.. firmer sidewall but still drive well in weather and i ran stock 16x6.5" wheels w/ no strange tire wear.
        All of this can be done for relativly low cost.... You can also pick and choose what you want to do..
        http://www.overkillengineeringmotors...198wbody2.html has Koni's, camber plates, tubular control arms...
        S
        Shane "RedZMonte"
        1992 Lumina Z34-VIRGIN (RIP)
        1992 L67 Lumina Z34 (SOLD)
        1990 Turbo Grand Prix (SOLD)
        • Sonyman
          • Jan 2008
          • 160
          Im interested in knowing if someone has came up with a way to get rid of the monoleaf transverse spring
          in favor of spings like everybody else. Please let me know.
          • LuminaPower92
            • Apr 2005
            • 8
            Birchmount makes a steel (heavier) lowering leaf spring for the rear for whatever height your looking for.
            I have front intrax springs made for the W-body group buy from a 95-99 monte carlo
            and a rear birchmount spring made for a 2.5 drop.
            Perfect combination for my car, came to be almost dead even.
            Car stock when i got it
            After Intrax only install.
            After Brichmount Lowering Leaf
            • grandprixgtp_93
              • Feb 2010
              • 75
              thanks guys i appriciate it i have some zzp rear arms my front springs and my struts so far im about to order the rear swaybar and monoleaf
              • grandprixgtp_93
                • Feb 2010
                • 75
                where do i find the birchmount spring ive been looking but cant find one
