2003 Chevy Malibu Suspension
  • Kaos
    • Mar 2014
    • 122
    I am playing hell finding anything for my car in the way of suspension. I am guessing what I will have to do is compare weight and dimensions and everything with other cars and piece together my own setup. I think for the time being I will go with KYB AGX struts and some cheap ebay adjustable coil sleeves. Just gotta figure out what length and spring rate I need. If anyone has any pointers or ideas, let me know.
  • young gun
    • Jul 2010
    • 250
    Call WOT-Tech. Spend <1k and have good coilovers. Buy speedbuilt front and rear sway bars(might still have some on PFYC.com if not I have seen them pop up on GAOC.com. Strut tower bar. Alum control arms from 99 GA with poly bushings. Rear lateral links 3 options (BMR lat links for a GP, junkyard GP's lat links (tubular vs our U shape), Just box in the stock U), Same goes for rear trailing arm. Light weight rims and I think that is is.
    • Kaos
      • Mar 2014
      • 122
      Young gun you rockin a malibu too? Thanks for the list
      Sent from my iPhone using Tapatalk
      • young gun
        • Jul 2010
        • 250
        Nope. GA=Alero=Malibu for 97-05.
        Here is my Ho from this wonderful winter season
        Because I want to...
        • carbon
          Procrastinator
          • 388
          Just to clarify... Alero was 1998-2004, Malibu was 1997-2003, and the Grand Am was 1999-2005. God, GM was a mess...
          The lateral links on the W-body were the same length as the N-body? That's cool...
          - Ben
          • young gun
            • Jul 2010
            • 250
            Haha yes.
            Yes. Just need to sleeve the links or drill a bigger hole into the N body rear frame.
            • Kaos
              • Mar 2014
              • 122
              Loving this thread. Let's keep the knowledge flowing.
              • young gun
                • Jul 2010
                • 250
                We drive middled aged women's grocery getters...
                • Kaos
                  • Mar 2014
                  • 122
                  Real talk. Lol. Nice pass up there. Just watched it.
                    That's where I got sleeves and nuts to replace my seized ones. I think I paid about $25/side, but I already had the upper perch for the spring. I also reused my old springs. Just throwing that out there if you go DIY.
                    As far as tube links on the GP, I think that's like 98 or so and newer. I replaced my stock U ones with 2000 Monte ones from Dorman and pressed out the rubber bushings and put my poly ones in.
                    • Kaos
                      • Mar 2014
                      • 122
                      Where did you get your poly bushings. I want poly EVERYTHING
                        They were on the car when I bought it. The PO had bought basically everything an old company (with a not so hot reputation) called RSM made for the W body.
                        Energy Suspension makes way more sizes of poly bushings than you realize, and they have them listed by size. You may be able to piece together a full poly bushing setup by going through their catalog and matching sizes if you can't find any kits. I would use online replacement parts catalogs like Advance and Rock Auto to find the size of stock bushings if it comes down to it. I would also post up what you find that could become a sticky like what we have for the W platform.
                        Edited because my dumbphone thinks fir is appropriate to use in place of the word for.
                        • Kaos
                          • Mar 2014
                          • 122
                          Lmao. That is a good idea. I will post what I find
                          • young gun
                            • Jul 2010
                            • 250
                            Look up on GAGT.com I feel like there was something to help with this. Control arm bushings and sway bar end links I already know you can get those poly. It is the rear you need to be concerned with
