I am playing hell finding anything for my car in the way of suspension. I am guessing what I will have to do is compare weight and dimensions and everything with other cars and piece together my own setup. I think for the time being I will go with KYB AGX struts and some cheap ebay adjustable coil sleeves. Just gotta figure out what length and spring rate I need. If anyone has any pointers or ideas, let me know.
2003 Chevy Malibu Suspension
Call WOT-Tech. Spend <1k and have good coilovers. Buy speedbuilt front and rear sway bars(might still have some on PFYC.com if not I have seen them pop up on GAOC.com. Strut tower bar. Alum control arms from 99 GA with poly bushings. Rear lateral links 3 options (BMR lat links for a GP, junkyard GP's lat links (tubular vs our U shape), Just box in the stock U), Same goes for rear trailing arm. Light weight rims and I think that is is.14.63@92.9 -Full LX9 with CAI, 65MM TB, 2.5in DP, Borla Cat-Back, Crappy tires, Quick tune (Dyno Soon)
Just to clarify... Alero was 1998-2004, Malibu was 1997-2003, and the Grand Am was 1999-2005.
God, GM was a mess...
The lateral links on the W-body were the same length as the N-body? That's cool...sigpic
- Ben
Haha yes.Originally posted by carbon View PostJust to clarify... Alero was 1998-2004, Malibu was 1997-2003, and the Grand Am was 1999-2005.
Yes. Just need to sleeve the links or drill a bigger hole into the N body rear frame.Originally posted by carbon View PostThe lateral links on the W-body were the same length as the N-body? That's cool...14.63@92.9 -Full LX9 with CAI, 65MM TB, 2.5in DP, Borla Cat-Back, Crappy tires, Quick tune (Dyno Soon)
We drive middled aged women's grocery getters...Originally posted by Kaos View PostLoving this thread. Let's keep the knowledge flowing.
Sent from my iPhone using Tapatalk14.63@92.9 -Full LX9 with CAI, 65MM TB, 2.5in DP, Borla Cat-Back, Crappy tires, Quick tune (Dyno Soon)
Shop racing parts and automotive accessories from top brands like Wilwood and Simpson. A-1 Racing has offered brake kits, safety gear & more since 1927.
That's where I got sleeves and nuts to replace my seized ones. I think I paid about $25/side, but I already had the upper perch for the spring. I also reused my old springs. Just throwing that out there if you go DIY.
As far as tube links on the GP, I think that's like 98 or so and newer. I replaced my stock U ones with 2000 Monte ones from Dorman and pressed out the rubber bushings and put my poly ones in.
Sent from my HTC One X using TapatalkLast edited by pocket-rocket; 04-14-2014, 03:03 PM.-60v6's 2nd Jon M.
They were on the car when I bought it. The PO had bought basically everything an old company (with a not so hot reputation) called RSM made for the W body.
Energy Suspension makes way more sizes of poly bushings than you realize, and they have them listed by size. You may be able to piece together a full poly bushing setup by going through their catalog and matching sizes if you can't find any kits. I would use online replacement parts catalogs like Advance and Rock Auto to find the size of stock bushings if it comes down to it. I would also post up what you find that could become a sticky like what we have for the W platform.
Edited because my dumbphone thinks fir is appropriate to use in place of the word for.
Sent from my HTC One X using Tapatalk-60v6's 2nd Jon M.
Look up on GAGT.com I feel like there was something to help with this. Control arm bushings and sway bar end links I already know you can get those poly. It is the rear you need to be concerned with14.63@92.9 -Full LX9 with CAI, 65MM TB, 2.5in DP, Borla Cat-Back, Crappy tires, Quick tune (Dyno Soon)
