Foot brake pedal not popping back up
  • packardbell
    • Jul 2014
    • 91
    Question : Foot brake pedal not popping back up
    Okay I don't have a 100% percent working foot brakes on my 1988 cutlass supreme.
    Last few years I replace the rear right and left cables that connect to the rear calipers.
    Still it would not function 100% trouble free, it would stick and I would need to crawl down and use a pair of pliers and pull back the cable so it disengages completely.
    Well this morning I got a new cable section that connects to the foot pedal and replaced it. Now the problem I have is trying to free the rusted long threaded cable end and the nut for adjustment. I have tried heating it up with a torch, it squeaks a bit but does not move. Then some liquid wrench and still nada.
    the early w-body e-brake does some really stuff at times.
    for instance, you may want to take a look under the dash and make sure everything is operating correctly there. when certain parts run dry, they stick, usually causing the pedal to follow your foot(so you get e-brake operation while you're pushing on it but it acts as if the release lever is always pulled).
    • carbon
      Procrastinator
      • 388
      That is for epic drifting action in the winter time and on dirt roads... is feature, not bug. I hate GM brakes. I hate Ford brakes too... never owned a Chrysler product that wasn't a Mitsu and the jury is still on my Kia as I've only had it for a month.
      - Ben
      • packardbell
        • Jul 2014
        • 91
        when you think all my car problems have come to a full stop. Still unable to loosen the brake equalizing thingy the long threaded part of the passenger brake cable snapped in half. Now I need to order a new cable and replace it. What else can break and fail on me now?
        BTW the new front brake cable is working fine as it pops back the pedal, so the old cable was seize or rusted internally.
        • packardbell
          • Jul 2014
          • 91
          • packardbell
            • Jul 2014
            • 91
            I replaced the passenger side brake cable. any ideas how to get that broken threaded section out of the nut?
            I was thinking of cutting a slot using a dremel and then using a screwdriver to hold it while I use a wrench to turn.
            • unchained01
              • Jan 2011
              • 388
              heat is your friend here
                a new equalizer isn't particularly expensive..... and neither would be the other rear cable at this point. i'm actually having to replace the entire length myself on the MC, i've had to rely on it to stop the car without hydraulic brakes a few too many times and now it nearly drags on the ground when not applied and doesn't actually have an effect when applied now either.
                • packardbell
                  • Jul 2014
                  • 91
                  yes I heated it up and it was moving and then snap. you can see the last picture it is black color from the heat.
                  how much is an equalizer? rockauto? got to have the emergency brakes, and brakes 100% working before winter hits.
                    i just got an ACDeldo one off of ebay for slightly less than it would have cost on rockauto.
                    http://www.ebay.com/itm/261570717885
                    • packardbell
                      • Jul 2014
                      • 91
                      Great score on the equalizer. Well the one on the car is still good, since I am already dumping alot of money for repairs on the cutlass. If I cannot get the threaded part out then I have no choice to buy a new one. Damn car better drive like new after I get all these repairs done on it. lol!
                      • 1988GTU
                        LB62LHObbqftmfw
                        • Nov 2005
                        • 2475
                        Just grind it off if you insist reusing it.
                        Fyi its 'Parking Brake'. Not intended for emergency stopping a vehicle.
                        • packardbell
                          • Jul 2014
                          • 91
                          Yeah I ended up taking out the equalizer and torching the crap out of it, finally got the threaded part out of the nut. I got to rustproof it with something so next time I don't need to go through this again. Damn rust. Oh I got to check the drivers side rear cable to make sure it is moving or might need to replace it with a new cable too.
