tricks so I do not have to service my rear brakes
  • packardbell
    • Jul 2014
    • 91
    Question : tricks so I do not have to service my rear brakes
    I do know that these brakes on these W body cars kinda sucks moose balls. It seems like you need to service them on a yearly basis or you have to replace rotors and or seized caliper sleeves/bolts. Is the design on the rear prone to water ingression?
    One time I replaced the sleeves with these non metal ones, I think it was like light green ceramic which they say will never rust hence not seizing. Guess what? those ceramic ones seized as well, then you got the rotors rusting because the pads do not even touch the rotor surface. Besides removing them each year and disassembling and lubing it all up what do you use or special grease? I will need to replace the rear pads and rotors and not sure if the sleeves are seized again.
  • 19Cutlass94
    • Apr 2005
    • 770
    You should be servicing the brakes every time you rotate the tires. That includes lubing the caliper slides. Every 3-5,000 miles.
    3400/Getrag 284 5spd
    350/NV3500 5spd
    2014 Chevrolet Malibu LS
    • packardbell
      • Jul 2014
      • 91
      Okay, I am getting lazy and looking for a product or sleeve grease that will not wash away, or deteriorate from winter's salt and calcium.
      Looks like I will need to get off my lazy ass.
      • 1988GTU
        LB62LHObbqftmfw
        • Nov 2005
        • 2475
        Take the bolts in to have zinc plated and use synthetic high temp lube grease not oil for the sleeves.
        • packardbell
          • Jul 2014
          • 91
          The zinc coating sounds excellent but it would need to be done at a specialized shop? I can buy the synthetic high temp lube at the local shop.
          • 1988GTU
            LB62LHObbqftmfw
            • Nov 2005
            • 2475
            You can probably do it yourself, but the cost would be high for start up.
