I gots the blingity bling GTU wheels on the Sunbird
  • RidgeRunner
    • 971
    Yes, the wheels have had their clearcoat stripped... and yes the car is dirty. But that comes with driving on dirt roads alot. I've got ContiTouringContact 225/50-16 tires. They do fine just driving along, but when I hit a hard bump or turn real hard they rub a bit. I need to find out where...
    I need to finish re-doing the wheels, but I was in desperate need of tires so I went ahead and put a set of ContiTouringContact 225/50-16 on the GTU wheels. Discovered that one wheel was pretty badly whopperjawed on the inside rim, but it doesn't seem to affect ride quality.
    The goofy tire shop had a hell of a time getting the tires over the rims. It took 2-3 guys pretty much putting their combined weight on the sidewall to push it down enough for the machine to pull the tire over the rim.
    So far I like them alot. Since they're a lower profile, I'm feeling every little ripple in the pavement, but that's no big deal.
    60v6's original Jon M.
  • pepsi_coke
    • 288
    Ever think of sandblasting the rims ?
    Can you fit 245-50s on those ?
    New member of 200,000 mile club as of May 16, 2005
    • JamesonGT282
      • Jan 2005
      • 208
      245's will rub on an L body with 16x7's so I would assume the same for a J body.
      You have had those rims forever, glad to see em finally on. The more L body you have in'er the better your J will be :P
      '91 Beretta GT 282 swap GONE
      '98 BMW M Roadster stage 2+ boosted
      '06 Saab 9-5 wagon 5mt tuned
      '11 Saab 9-3 XWD tuned
        • 13525
        Either way you look at it, its still not a w body:P Those do look good though, despite the finish. I am running cutlass rims on the GP and they are in horrid condition (but look good anyway).
        • RidgeRunner
          • 971
          That'd be much too big in width and diameter. Right now, the 225/50s come right out to the edge of the fender, and even scrub a bit if I hit a hard bump.
          • RidgeRunner
            • 971
            Thank goodness. :P
