how do you think this stuff would do together?
  • GPRacer
    • Mar 2005
    • 161
    KYB GR-2's all around
    INTRAX up front
    Birchmount in rear with polyurethane bushings
    polyurethane sway bar bushings (front/rear)
    I'm hoping this is going to be stiffer than fuck! That's all the shit i HAVE
    Right now the front is COMPLETE. All bushings/springs/struts, done.
    Rear is like 1/3 done
    One KYB is in, poly bushing on the anti-sway bar, and wheel's back on. New brake pads as well.
    I'm trying to get those Stainless brake lines...but i'm bidding on something on Ebay that just might hold me back from that for a little while
    • 13522
    RE: how do you think this stuff would do together?
    I would like to see something other than polyuerethane being used. You gotta grease it to keep it from making noises, and trust me, it gets annoying. It does rock though otherwise
    What about the rear sway bar?
    • AWeb80
      W-body RSTB Maker
      • Feb 2004
      • 392
      and a rear stb from me will help too....
      Rear STB Purchasing INFO
      • GPRacer
        • Mar 2005
        • 161
        Re: RE: how do you think this stuff would do together?
        The good thing is, the polyurethane bushings i got are greasable. They came with a bracket, as well as a fitting for a grease gun to go to
        as far as the rear sway bar, i'm debating gonig with a bigger sway bar, or going with the rear STB. I don't wanna do both, because my backend's slid out from me before with the stock setup, so i don't wanna stiffen it up TOO much, or it'll be all over the place.
        AWeb-weren't you saying you couldn't drop your car too much with the coilovers due to the larger sway bar? IIRC you said you couldn't drop it too much because the larger sway bar was interfering with something.
        Plus your STB is probably cheaper, more effective, and looks cool
        I get paid tomorrow...we'll see how much i get. I'm buying a TGP interior from a guy off the W, but i need to save as much as possible for gas! Once i get the car going i'm going to blow through gas!
        • AWeb80
          W-body RSTB Maker
          • Feb 2004
          • 392
          RE: Re: RE: how do you think this stuff would do together?
          Well, I had problems with my car being lowered, but that is fixed now.
          I have the RSTB and the sway bar and i don't have problems with my backend sliding out.....my car is pretty neutral....for FWD anyways.
          I can get the back to slide out if i want it, but i have to try....it has never just happended
