Are all 4T60E's the same?
  • Jbrogan
    • Oct 2006
    • 203
    There is a 4T60E on a corsica at the junk yard. is it the exact same as my 4t60e on my beretta? i know that in my corsica that had a 3spd the gears were longer than my 3spd beretta. so are the gears longer in the corsica with a 4t60e? im not puttin in a trani with longer gears. also i found alot of 4t60e's that inside the car is a collumn shift and it reads all four gears, and the beretta is on the floor and reads Low, drive, and overdrive, so how would this work? Is it the same trani or not?
    1996 Beretta
    3100 SFI TURBO
    13.1 @ 103 mph best in the 1/4 mile
    • 13533
    They are all the same minus the FDR. That would make it longer/shorter through the gears.
    Im not sure if a 94-95 is the same as a 96 though. I need to know that for my 96 GTP as I have 2 transmissions here now. If you use a 3.1 W body and a 3.4 W body transmission, you can make a 3.73 fdr. That would be shorter than your stocker
    • MMGT1
      MMGT1
      • Aug 2006
      • 104
      Could you tell me what I would need to do this? Would love to shorten the gears a bit in my GT,(2000 GA GT1) but didn't know it was possible! Thought I had to do a GTP conversion or something.
      Paul
        • 9191
        There are actually several different models of 4T60E in just the same year, so you really have to match tranny codes to get an "exact" match. Differences include what sensors are used and could alter the internal wiring some.
          • 9191
          3.73 Final Drive Instructions
          • MMGT1
            MMGT1
            • Aug 2006
            • 104
            Dam! Good stuff.....
            Cheers!
            Paul
            • Jbrogan
              • Oct 2006
              • 203
              What trani codes are you talking about?
              1996 Beretta
              3100 SFI TURBO
                • 13533
                Damn you GM! haha, ok, well I can pull the original first if I have to but id rather rebuild one and swap it.
                  • 9191
                  There is a tag on the tranny house with a 4 digit code.
                  http://60degreev6.com/Articles/Trans...T60E/4T60E.htm
                  The ones with a 6 for the first digit are 96 model year IIRC (15 different models).
                  • sharkey
                    • Jun 2004
                    • 2061
                    Paul
                    a 2001 gagt will have a 4t45e, not a 4t60e. im not sure, but a 4 cyl 4t40e may use different gearing than the v6, so there may be parts avalible to do a gear swap.
                    • Jbrogan
                      • Oct 2006
                      • 203
                      that helps some. so the corsica trani would have a different final drive ratio? What about tranis with different codes. is it possible to find a better one? if so what is the best trani to put in my 96 beretta 3100.
                      1996 Beretta
                      3100 SFI TURBO
                      • Jbrogan
                        • Oct 2006
                        • 203
                        do 96 4t60e's in berettas suck? because mine went and so did the one at the junk yard, but my freind has a 95 beretta 4t60e and we do burnies in it all the time and it is fine, now wtf?
                        1996 Beretta
                        3100 SFI TURBO
                        • Jbrogan
                          • Oct 2006
                          • 203
                          my trani is a 6WFW, good, bad? will any other tranis work.
                          1996 Beretta
                          3100 SFI TURBO
                          • MMGT1
                            MMGT1
                            • Aug 2006
                            • 104
                            Yea, my trans is a 4T45E. 2000 Grand AM GT(329 final drive, factory)
                            So, there is nothing that can be done with this one?
                            • Jbrogan
                              • Oct 2006
                              • 203
                              my fdr is 3.29, would a 3.33 fdr make it faster?
                              1996 Beretta
                              3100 SFI TURBO
