Adjustable Modulator 4T60E
  • geldartb
    The Situation
    • May 2004
    • 1994
    the car spends lees time doing this oh wait i want to shift not now not now, and when its too late it shifts.
    instead you can have it go i wanna shift almost like bam and your there no hanging around waiting for it to shift.
    plus no more sloppy shifts.
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
    • PCGUY112887
      • Feb 2006
      • 1067
      Careful getting it at Advanced, here their computer substituted it for a non-adjustable one. Ensure it's a Pioneer one.
      SpudFiles
      Theopia
      Enjoy life online.
      • GremlinZ34
        Other Member
        • Sep 2006
        • 23
        will do. thanks PCGUY.
        1992 Lumina Z34: Artic White on Gray -Auto
        1987 Porsche 944: Slate Gray Metallic on Burgandy- Manual (Possibly for sale)
        • Z3R0
          • Nov 2006
          • 90
          Is this compatible with the tranny in my 97 monte carlo ls...I think it is a
          4T60E...I think.
          Originally posted by wozxx...{is 92 mph in a school zone illegal?}
          I was going relatively fast thru a school zone and was caught. However, I managed to zip into a neighborhood and evade the cop. Could I get additional tickets by trying to run?
            Yes it should be if its a 4t60e
            • PCGUY112887
              • Feb 2006
              • 1067
              #21
              Now... what the metal vac lines plugs into on the tranny, is that a modulator? Is this adjustable one supposed to be a replacement for that? Seems like it should be, but it's much smaller and doesn't have the vac port pointing in the same direction. Sure I could go find a T or something, but if it's a replacement I shouldn't have to?
              SpudFiles
              Theopia
              Enjoy life online.
              • IsaacHayes
                Mr. Orange.
                • Apr 2006
                • 6030
                #22
                747017 Shows up as 83-91 4T60E on oriellyauto.com. Perhaps that's why the vacuum port is in a different spot?
                If you could do post pictures of the replacement. It is just unscrew and replace? I might want to do this to mine.
                I'm assuming your 96 is still vacuum controlled modulator? I thought 96 when they went OBDII the trans became fully electronic and controlled line pressure via electronics not vacuum??
                • geldartb
                  The Situation
                  • May 2004
                  • 1994
                  #23
                  96 still had the vacuum modulator. cause i took one off a 60k mile 96 4t60e.
                  99 Grand Am GT
                  • PCGUY112887
                    • Feb 2006
                    • 1067
                    #24
                    Yes still vac controlled... I don't know what year it went to all electronic... I wish mine was I could just change the pressure with my Powrtuner.
                    83-91 didn't even have the 4T60E, the E didn't come till like 93...
                    New adjustable vs the one in the transmission. Not only the vac port moved, but it seems a good bit smaller than the one in the tranny.
                    The new one did come with a piece of hose, angled at 90*, it may hookup with that hose I am not sure.
                    Anyone know why they used a metal line vs a regular rubber vac hose? Because of how close to the exhaust it gets?
                    SpudFiles
                    Theopia
                    Enjoy life online.
                      • 9188
                      #25
                      4T60E came out in 91 : http://60degreev6.com/showthread.php?t=25029
                      4T60E has never been fully electronic. It has always had a modulator, even on OBD2. The 4T65E is the fully electronic version.
                      • IsaacHayes
                        Mr. Orange.
                        • Apr 2006
                        • 6030
                        #26
                        Ah got ya.
                        For some reason this popped into my head, but a 94 buick with a 3100 I saw had a weird plenum, throttle body, and other things. It had a MAF too. I wonder if that was the one with the OBD1.5 with removeable prom? </offtopic>
                        Stock metal line is just for reliability, as you said the exhaust is there, and rubber can rot, and tear/etc. So they went with hard line. Plus it stays in place better. On mine it T's off at the modulator and goes to my vacuum tank with a check valve there. But looks just like yours, and says Holley on it.
                        The replacement I wouldn't worry about the size, just different brand/construction. It came with a 90* elbow to make it work with the stock routing it seems. Use that and you should be fine.
                        Is replacement as simple as pull out and push new one in?
                          • 9188
                          #27
                          Yes, it is the one with the removable PROM.
                          • geldartb
                            The Situation
                            • May 2004
                            • 1994
                            #28
                            my 4t45e is totally electronic too. its nice to be able to adjust the pressure with dhp, but its a pain in the butt when doing a ve tune cause when you unhook the maf to get the scan data it jacks the trans pressure up to the max.
                            99 Grand Am GT
                            • IsaacHayes
                              Mr. Orange.
                              • Apr 2006
                              • 6030
                              #29
                              Does this reduce the time on downshifts any? It seems sometimes my car downshifts fast, some times it takes is time going from 3rd to 2nd then to 1st. Other times it's just bam and goes. Upshifts seem to be quick pretty much all the time, with the front breaking free on rough roads sometimes hehe
                                use the rubber 90* it will fit perfect.
                                A pic of mine a long time ago.. Remember I have vac lines tapping off for the hvac controls, yours doesnt have all that crap.
