1993 Z34 5-Speed swap
  • 93LuminaZ34va
    • 144
    What all is needed? I know the obvious, the Getrag 284, matching CV axles, if they are different, the pedal assembly, and whatever is included in the shifter mechanism (Does it need a whole different console from the automatic?), and the matching computer,calpack, or chip (which one?)....... Looks like this deal with the 1998 Z28 might be falling apart, if the car can't clear inspection and I've decided rather than going in the hole for another car, the Z34 is gonna get the attention it always should have got. I will also be reading up on all those turbo DOHC discussions again
    1993 Chevy Lumina Z34; 4T60-E, CATCO 2.5" hi-flo cat, Flowmaster Exh, American Racing Aero Rims, KYB GR-2's
    1999 Tacoma SR5 TRD 3.4V6 4WD, lift, tires, rims, exhaust, couple of tricks
    1962 Buick Electra 225 STOCK... and gonna keep it that way
    • 13531
    Just need the pedal to mount in there, modify the hole in the firewall for the clutch hydrualics, memcal only, drill hole in floor board for shifter cables, install the tabs to bolt the shifter to the floor board, change 2-4 wires I think, turn off the clutch switch and not worry about it, plus more.
