time for service
  • sprucegagt
    Old School KI
    • May 2005
    • 703
    its on the front. if you look around on grandamgt.comn theres a thread on how to install a trans temp gauge and where you put the gauge sender is the plug where you would check the fluid
    The plug were you put the trans temp sensor is not the same plug for checking the fluid level in the trans. The trans temp plug is on the front of the trans, while the fluid level plug is on the snout for the passenger side half shaft.
    Your local OBDII moderator
    2000 Grand Am GT w/ WOT parts
