1997 Chev Malibu, 4T65e I believe... no dipstick to see condition of fliud, don't care, want to change it anyway, anybody know the capacity upon refill. I'm only dropping the pan and replacing the filter. Thanks
time for service
Tags: None
sounds like a 45e since its got no sipstick.sigpic
99 Grand Am GT
1357 cam 227 233 .050 dur 515 515 lift 112 lsa
thats another wonderful thing gm decided to do.sigpic
99 Grand Am GT
4T45-E
bottom pan remove: 6.9 quarts.
I would say look in the wiki (I did an article on the 4T40-E/4T45-E), but the wiki is down right now.Taylor
1998 Lincoln Mark VIII
make sure you dont screw the gasket up. its like 60 bucks from the dealer, and thats the only place you can get it.sigpic
99 Grand Am GT
There should be a plug somewhere on the side of the transmission you can use to get the level right. Just make sure the car is up evenly on all four sides and remove the plug before you fill it. When you think it's almost full, pour slowly till the fluid comes out the hole. Then put the plug back in.
99 Grand Am GT
awsome... thanks. my trans shudders a little when the throttle is held just so and it shifts from first to second, other than that it will shudder a little WOT shifting too... i think she's going to pack it in on meOriginally posted by TazMan View PostThere should be a plug somewhere on the side of the transmission you can use to get the level right. Just make sure the car is up evenly on all four sides and remove the plug before you fill it. When you think it's almost full, pour slowly till the fluid comes out the hole. Then put the plug back in.
posted a pic of where it is
alright heres a page from pfyc.com on how to install a trans temp gauge just use it for the driections on where the hole is
for the shudder you could just be low on fluidLast edited by geldartb; 01-28-2008, 02:51 PM.sigpic
99 Grand Am GT
try the trick with the pic i posted. you do it with the car running and it should dribble out the hole.sigpic
99 Grand Am GT
