284 v. 282
  • rsisbetter
    • Mar 2006
    • 151
    284 v. 282
    what is the difference between thetwo? is the 284 stronger, or have different fdr?
    thanks
    • 13533
    284 is about 50 pounds heavier, and harder to get parts for (impossible nearly). Its stronger, and uses a pull type clutch vs push type for the 282. 3.61 i think is the 284 FDR. Its close ratio as well, similar to the 282 out of the 190hp quads and something else I think. That 282 had a 3.94 as well. brian89gp.com used to have the charts but I dunno if that is still up.
    • torq455
      If I only had money!!!
      • 1615
      you don't want that 3.94 FDR! 3500 rpm at 60mph will suck!
      Andy
      fastest 1/8: 10.19@ 67.17
      fastest 1/4: 16.16@ 82.70
        Yes it does!
        that's why i'm swapping the 3.61 FDR into my W41 tranny
        • torq455
          • 1615
          no it's not Dave!! you're swapping cause you went faster in the 1/4!!
          Andy
          • rsisbetter
            • Mar 2006
            • 151
            haha, i was wondering since i had seen a couple in the jy's before, and didnt know if they were stronger or better, than the 282, and should have taken it. in no way would i put any higher of a fdr in one of these trans!
            thanks for info
            cody
            • sharkey
              • Jun 2004
              • 2061
              i found it was more like 2850 at 60mph. however thts with the .81 5th gear, swap in a v6 5th gear (.72) and it drops you to 2450 at 60mph, wich was actualy perfect with my cam i was running.
