Optimum Trans fluid temp?
    Question : Optimum Trans fluid temp?
    Ok well I have a high stall converter in my car and well yeah it generates a little heat. I noticed with the stock cooling system the trans temp would climb quickly and I think it would easily reach over 200* F not sure how high since the one time I was logging it I saw 205 and then I went out and bought a Hayden pipe/fin cooler... not sure the exact size but it had 3 U's on one side. Well Saturday I was out driving and I noticed the temp again was up around 200, like 202 max, so I know temps like that arent that good but at the same time arent the end of the world... so I grabbed a Maxi-Kool XL cooler, supposed to be 33% more efficent than a pipe fin style.
    BUT my real question is at what trans temp should I really start to worry? is 200* bad for it? or is that around norm?
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    That is about normal. I installed a trans cooler (with gauge) into my buddies 3.4 gtp and the temps are sitting at about 185-199 and that is for a rebuilt stock trans with a slightly higher stall converter.
    • X11_STE
      • 386
      I've got an HD van that does some serious hauling and the trans stays around 180-200. Idd I was you, I wouldnt worry about it. Now, when tranny fluid reachs 420 degrees, it'll only last 20 mins before being trash.
      Tuning a car is full of compromises. You must decide if you are willing to give up either reliability, performance, or a whole load of cash. Also remember that repairs will seem to come up much more often as you strive for even more performance
        420*!!!! HOLY HELL... I think the 300 mark would be way pushing it...on the back of my cooler it says, 315* "seals and clutches burn out, carbon forms" 800miles max... LOL
        for 195*f it just says approx 50,000 miles of use or so...
        and 175* 100,000 miles of use... I'm sure thats a little exaggerated but I wouldn't mind seeing 180* constant, rather than 205*
        The new style cooler I got looks like a mini coolant radiator, it has two tubes down each side which are connected with runners that have normal type fins between them, there is a total of 30 runners, so I'm sure this cooler should work a bit better than the tube fin style one.
        Pics do better talking... this is the one i got.
        • 1988GTU
          LB62LHObbqftmfw
          • Nov 2005
          • 2475
          Is that a 8" by 9" with a 1.5" core? You could possibly put a little cooling fan in front of it to cool it more. Just wire it to spin on when XXX*F is reached.
            11 3/8 x 11 with a 3/4" core
            Largest one of that type... the smaller one is 7 1/2 x 11 with a 3/4" core.
            • loner666
              • Oct 2006
              • 435
              I'm putting in an extra fan on top of my cooler and possible another cooler to keep mine down..not sure the exactly temp in F but Ive been seeing around 80-85C so I don't. Seem to be alot happier then my last one was so far
              Best 1/4mile ET - 12.9
              Best 1/4mile MPH - 111
              1997 Ford Ranger Splash
              Daily Driver
                edit your gauge to display F
                85 is only 185 tho
                Its my damn converter that generates so much heat slipping as much as it does.
                • IsaacHayes
                  Mr. Orange.
                  • Apr 2006
                  • 6030
                  low stall FTW just ribbing ya
                  I'll scan mine sometime now that it's hot and humid outside and see where it's at. I don't have headers or high stall so it's going to read what a "stock" trans should... I have seen around 200 though before IIRC. It's always hotter than the motor is from what I remember.
                  Hmm, my trans has like 215,000 on it, so it must be running at 130F then huh? LOL :P
                    1650 stall with this cam would probably suck and bog badly... Maybe a 2300 wouldnt be bad though... we'll see after I get some numbers.
                    • PCGUY112887
                      • Feb 2006
                      • 1067
                      I have the mini radiator type of cooler as well, big one made for RV's and shit.
                      My temps are around 170-180 with a stock converter and higher tranny pressure.
                      SpudFiles
                      Theopia
                      Enjoy life online.
                        I had one on my 91 for a long while before I put a 284 in it. The trans that was in the car at that point had 99k miles on it, which in a Z34 is a wonder how it was still going. At any rate, with that cooler I got 30k miles of hard driving out of it, so I was happy with my investment.
                          I got it installed last night but I didnt scan it when I was joyriding after the 3500 upper swap... I'll check it on my way up to epping on the highway... I cant see how it wont make a difference, it was almost twice the height of the old one, and it's not just 6 straight lines of a pipe going through fins...
                            Well IIRC the one you and I have is rated for something stupid like a 16k lbs truck.
                              yeah like 10,000 lbs towing too I think...LOL
                              Up to Class "A" Motorhomes, Towing up to 10,000 lbs
                              I would hope this cooler helps...
