which one is right tranny for 3.4 DOHC (93)
  • MOTORHEAD
    • Mar 2008
    • 90
    which one is right tranny fit for a 1993 3.4 DOHC ? 4T60e or 4T60-HD? or 4T65? im too confused, i have seen 3.4 DOHC with 4t60e or even 4t65 its based on years of 3.4 DOHC or?? or even have '-HD'??? which one is right one? i need it asap i just blew mine
    -1992 Red Z34 284
    -1990 TSTE
    -1991 GTP
    -1992 B Z34 parts
    -1992 R Z34 parts
    • 13525
    93 3.4 DOHC is 4T60-E with a 3.43 FDR. Pushrod W body in 93 was a 4T60-E with 3.33 FDR. 97 3.4 DOHC was the only to come with a 4T65-E and thats not all of them either. Only the 3.4 DOHC had the 3.43 FDR so you will want to make sure you keep that for the best drop in.
    • MOTORHEAD
      • Mar 2008
      • 90
      soo this 4T60-E with FDR 3.43 is better? what is that pushrod w body tho? i know w- body is but whats difference by pushrod w body? better to use 4t60-e instead of 4t65-e?
      -1992 Red Z34 284
      -1990 TSTE
      -1991 GTP
      -1992 B Z34 parts
      -1992 R Z34 parts
        • 9190
        Your stock PCM can't control the 4T65-E, so you must install a 4T60-E.
          • 13525
          well, the 3.4 DOHC is DOHC, not pushrod. 3.1 grand prix in 93 had the same trans but 3.33 FDR. Your shift points are based on MPH, not RPM so it would shift at lower RPM than it does now...slightly. Its not a huge deal IMO but a 3.43 would be what I would want to put back in.
          • MOTORHEAD
            • Mar 2008
            • 90
            allright many thanks. now i get it pushrod r not dohcs. allright many thanks again
            -1992 Red Z34 284
            -1990 TSTE
            -1991 GTP
            -1992 B Z34 parts
            -1992 R Z34 parts
