Hey, looking for a 5sp for my sc 3800. Needs to be a 5spd. Does anyone know if that motor will bolt up to the 5spd trasn that some in the berettas?
3800 S/C bellhousing????
Although the 3800 is not supported much in this community i can tell you that Yes, the L67 shares the same bellhousing pattern as the 2.8/3.1 in the Berettas.Originally posted by BLK96Z View PostHey, looking for a 5sp for my sc 3800. Needs to be a 5spd. Does anyone know if that motor will bolt up to the 5spd trasn that some in the berettas?
You will need to get a flywheel for a 3.8 5 speed Camaro and have it machined down to the thickness of the Beretta/Cavalier flywheel, then use a good performance clutch for a Beretta/Cavalier.
No problem..
you should bookmark the following link, alot of other engines share the same bellhousing as well.. even some V8's
