4T60-E Trans Cooler Supply
  • 94GPGTP
    95 Grand Prix GTP
    • Apr 2007
    • 593
    Question : 4T60-E Trans Cooler Supply
    Does anyone know which line is the supply for the factory trans cooler?? I am adding a external cooler to the factory and i am going to use the factory one first then the external one then back to the trans.. Im not sure which one is the supply though.. The top or bottom line on the radiator??
    Thanks
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    Drilled/Slotted Rotors
    White
    3" Magnaflow Catback
    90 Pontiac Turbo Grand Prix
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    230,000 mile Getrag 282
    Emissions Deleted
    Brand new Engine 1,000 Miles
    Fully Custom Built car
  • torq455
    If I only had money!!!
    • 1615
    not positive here, but i tend to think that gm would want to eliminate all air in the cooler lines. since air rises it's only logical to have the bottom line supply fluid forcing the air up and out of the cooler.
    Andy
    fastest 1/8: 10.19@ 67.17
    fastest 1/4: 16.16@ 82.70
      I think its top to bottom not sure... BUT coming out of the trans the vertical fitting is the supply the horizontal fitting is the return... trace them back from there.
      • 94GPGTP
        95 Grand Prix GTP
        • Apr 2007
        • 593
        Yep That was the one! i added the aftermarket cooler with the factory one and the fluid is way cooler then before!!! There is a noticable difference when you touch the inlet and outlet of the lines... Definatly the way to go if you want to perserve the life of your trans...
        Robert
        New Rebuilt 3100
        New Rebuilt 4T60-E
        Exhaust
        White
        5 Speed Swapped
        127,000
        Spec Stage 3 Clutch
        Emissions Deleted
        • david3100
          • Dec 2007
          • 36
          I've had two 3100/4T60E's that would not drop into Overdrive on the highway, sporadically. After adding the external coolers, they both drop into OD everytime.
          One I have going to the external cooler first and the other I have the lines routed to the radiator's cooler first. I see no discernable difference in the shifting.
          I bought a new transcooler off Ebay that doesn't flow when cold. That makes sense. It has stackable plates. The other cooler I pulled off of a 93 Pull-A-Part Regal. Same design and much cheaper.
