trans issus
  • jesterof84
    • Jan 2008
    • 24
    Question : trans issus
    ok well were to start i have a 92 Buick regal custom 3.1 T!!!!
    3.1 was the only joy i had in buying it well the engine good and strong little to no valve train noise
    my first car was a cavi 3.1 5 speed
    understanding that this car and that is like apples to oranges its almost half again the weight
    any way
    the trany has a good mind to do and say what it wants to when passing gear and overdrive are concerned and if its tcc
    well sometimes it will kick down some times it wont and
    same thing with in or out of over drive
    it is vacuum modulated and detent cable
    and the newest issu the speedo sensor just stoped working all together i need one
    if anyone has one
    it is a 4T60
    one more odd question im @ 125000 how do i service the diff cause i doubt its been done
  • jesterof84
    • Jan 2008
    • 24
    i posted this a day after the sensor died and so then that would be 17th ok so no funny to days later * ** * ** * ** ... ** **** haha the computer finely noticed
      • 9191
      I'm trying to figure out what your actual question is...
        Diff doesn't need to be serviced.... Some trans have a serviceable diff which just means you can replace the diff without taking the guts out of the trans to get to it.
        • jesterof84
          • Jan 2008
          • 24
          well one question was awnserd mustt be alldata listed diff fluid for it i just never finished looking
          2 the trany has a good mind to do and say what it wants to when passing gear and overdrive are concerned and/ or if its tcc
          it is vacuum modulated and detent cable maybe one or both is bad ?
          2. does any one have a speed sensor used thats known to work the cheapest around here is 83$
          even rock auto is like 89 before shipping
          main pont im not a trans expert i dont know if the signs ar the detrimental or just my imagination
          i do appreciate everyones input
            check the TV cables for sure to see if they are in proper order.
            Hit up a junkyard, maybe even www.car-part.com for the VSS.
            • jesterof84
              • Jan 2008
              • 24
              brand new vss didnt work why do you have to buy the hole ... thing if the coil it self unbolts is it likley to be defective ?
              • jesterof84
                • Jan 2008
                • 24
                i still have no idea how fast im going
