transmission replacement
  • techgeek27
    • Jun 2006
    • 60
    HEHE, yeah.. it was kinda fun dropping an almost 200 lb piece of aluminum to the ground.. as for the flush... done and done.. the trans is in and almost everything is done... I have a couple of bolts that have gone missing so i am waiting on them... *sigh*
    • techgeek27
      • Jun 2006
      • 60
      As for the align ment is there any home grown way of doing this..
        Originally posted by Rhedalert View Post
        you're braver than I am. I never want to pull a trans from the bottom unless I have a lift, supports, and a good transmission jack.
        I've done it without a lift and supports. I did use a pair of jack stands though, and a regular floor jack :P It sucked, but by-golly I got-r-done. I went at holding the engine up with a hillbilly method, but I am in Indiana, so I can do that :P I used a 4x4 with a chain wrapped around it with blocks inside the drip rail for the hood holding it up off of the fenders, lol. Yes, a lift would have been nice. Yes, so would a tranny jack, but you make do with what you've got :P
          http://www.elantragtclub.com/elantra/id554.html
          Google is your friend
          • techgeek27
            • Jun 2006
            • 60
            Help me please
            OK, bolts are obviously not coming from my freind and he has helped so much i am not hounding him about them ... the car still sits..
            help me please...
            I need the 2 bolts that connect the transmission to a right angle, for the most part, bracket that connects to the engine block. These are on the passenger side. WHAT ARE THESE BOLTS?
            If u give the info i might be able to just go buy them someplace.
            Please help. Maybe someone knows. I do not. I would love to know where these botls went. The only thing i can think is they went with the old transmission.
            • techgeek27
              • Jun 2006
              • 60
              #21
              OH BTW .. thanks for the allignment links.
