Beefing up a 4t45e
  • geldartb
    The Situation
    • May 2004
    • 1994
    Question : Beefing up a 4t45e
    ok ive read the thread that pop up under where im typing the title and 1 of them steamrolled into bullshit within the first few posts and the rest were useless.
    im gonna be picking up an uber low mile trans yard says it had 8k on it, so while its gonna be out of the car im wondering what i can do to it so that it will last under the power.
    does EP still sell the lsd's. last time i heard he was getting out of the buisness. does anyone have pics of the lsd's he sold for the 4t45 or the parts he used to make it. since they dont give the 4t45 a removable diff cover your forced to take apart the whole thing to do this.
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
  • asylummotorsports
    Banned
    • Oct 2005
    • 649
    In last heard form Jeff about a month and a half ago, and he was still flogging his stuff.
    I don't know about the 4t45e but the three 3t40 LSD's I have bought are GREAT!!
    I have a semi-recent phone number somewhere if you need it.
    • geldartb
      The Situation
      • May 2004
      • 1994
      ok cool i wont be diving into until this winter-ish time.
      could have sworn i saw it on one of these forums that he was kinda phasing himself out.
      ok so i dug up some info the one i found is an 05. but does anyone know exactly what GM did to these things in 03
      A 2003 or later transmission will have the latest durability updates to the stock parts from GM, so that would be your best bet as a starting point if you can find a low miles 03-05 4T45E trans. Keep in mind if you change to a GT trans you will need to run a GT program in the pcm because of the different final drive. Anything extra you do above that will depend on your budget and power goals, but they will all help the trans live longer and handle more power.
      99 Grand Am GT
      • double00bu
        HP_Junkie
        • Jan 2009
        • 19
        jeff is currently working on an LSD for me (4t40E) so,hes still at it
        only thing i know about changes to the newer trans is,the factory upgraded certain parts in valve body etc,that were prone to premature wear
        not much help i know but,if u contact jeff,i am sure he could tell u exactly,he knows his stuff on these trannys
        • torq455
          If I only had money!!!
          • 1615
          it took Jeff about 8 months, but i finally got mine. i've got about 12K miles on it now and have been thinking i shouldn't have wasted the money. grabbing one of the wheel and spinning it by hand used to be some work-- i could torque my lug nuts to spec with both wheels in the air. now, it's almost like there's just some drag on the brakes. i really doubt if my LSD is doing any good. the 4T45/125/60/65 trannys use the same differential.
          Andy
          fastest 1/8: 10.19@ 67.17
          fastest 1/4: 16.16@ 82.70
          • gectek
            I Hate Nose Hair
            • Aug 2006
            • 1472
            he told me that he is somewhat caught up and should be rolling through them again. had 8 sets of plates ready for diffs. that was about a month ago.
            • gectek
              I Hate Nose Hair
              • Aug 2006
              • 1472
              i did put a trans spreadsheet on here to look at
              i need to revise the pricing though.....alot of stuff has gone down as a matter of fact
              and the 4t40 trans does not use the same diff as the 4t60 afaik. i have seen both
                That sounds like you should be removing the unit and inspecting it to see what happened.... I have well over 12k on my clutches and its still pretty strong.
                They do wear out and you can get a new set of clutches from him if necessary.
                • torq455
                  • 1615
                  well, i wonder how much the Dex VI synthetic had effected the LSD.
                  Andy
                  • gectek
                    I Hate Nose Hair
                    • Aug 2006
                    • 1472
                    it "should" not. he orig said that because he did not know, but i think Mr Pink tried it out and it worked ok. there is no need to use the synthetic though unless you have the clutches that beg for it
                    • gectek
                      I Hate Nose Hair
                      • Aug 2006
                      • 1472
                      i put 20k HARD HARD driven miles and 1/4 miles on mine. no probs at all. a little noise on a hard bumpstop turn, but its ok
                        I'm running Dextron 6 and I haven't had an issue yet... I think it helps prevent some wear on the EP clutches if they do slip though.
                        I'll find out this winter... I'm going to go through mine to make sure the diff is all good, and possibly replace or resurface the spiders and clutches... as well as shim the springs a little.
                        • torq455
                          • 1615
                          sigghhhhh...i just might have to do that too.
                          Andy
