Where can i find a flywheel and clutch kit?
  • steevnz34
    • Sep 2009
    • 6
    Question : Where can i find a flywheel and clutch kit?
    Im looking for an aluminum flywheel and clutch kit or any other performance clutch parts for my 93 lumina Z-34. Does anyone know where to find this stuff?
    SPEC would have better clutches(pricey though...)... not sure about the flywheel.
    • steevnz34
      • Sep 2009
      • 6
      yeah ive seen what spec has to offer but not sure if im willing to spend that much yet. And the only performance flywheels ive seen are in fieros with aluminum fidanza ones, but when i look for these they say they dont make them.
      • 94GPGTP
        95 Grand Prix GTP
        • Apr 2007
        • 593
        i dont think theres a aftermarket flywheel for the 284.. You can pretty much only get a aftermarket clutch..
        Robert
        New Rebuilt 3100
        New Rebuilt 4T60-E
        Exhaust
        Drilled/Slotted Rotors
        White
        3" Magnaflow Catback
        90 Pontiac Turbo Grand Prix
        5 Speed Swapped
        127,000
        Spec Stage 3 Clutch
        230,000 mile Getrag 282
        Emissions Deleted
        Brand new Engine 1,000 Miles
        Fully Custom Built car
        • steevnz34
          • Sep 2009
          • 6
          So you are saying these guys that have fieros with the 3.4 dohc and are using fidanza aluminum flywheels are full of it? or is the flywheel matched to the tranny and not the engine?
          • 94GPGTP
            95 Grand Prix GTP
            • Apr 2007
            • 593
            yea the flywheels are matched to the tranny. The lightweights are for 282's. U could spend the money on a lightweight and find out if the clutch will bolt to it or not. All the 60v6 flywheels will interchange.
            Robert
            New Rebuilt 3100
            New Rebuilt 4T60-E
            Exhaust
            White
            5 Speed Swapped
            127,000
            Spec Stage 3 Clutch
            Emissions Deleted
            • steevnz34
              • Sep 2009
              • 6
              Thanks for the info. I will check out the price of the flywheel and go from there.
                The lightweights are for 282's. All the 60v6 flywheels will interchange.
                Contradict yourself much?
                Since when? That also contradicts your previous statements since "the 60v6 flywheels will interchange" meaning a flywheel for a 282 car would fit a 284 car... Considering you need your flywheel to bolt to your crank, and tooth spacing to be correct on the ring gear for the starter to mesh right, I would say they are more machined for the engine than the tranny.
                The Rockauto.com listing for a Rhino Pac flywheel for a 92 Z34 (284) lists these vehicles that their flywheel will fit in:
                CHEVROLET LUMINA 1990
                CHEVROLET LUMINA EURO (1990 - 1993)
                CHEVROLET LUMINA Z34 (1991 - 1993)
                CHEVROLET S10 PICKUP (1994 - 2003)
                GMC SONOMA (1994 - 2002)
                ISUZU HOMBRE (1996 - 2000)
                OLDSMOBILE CUTLASS SUPREME 1991
                OLDSMOBILE CUTLASS SUPREME INTERNATIONAL (1991 - 1992)
                OLDSMOBILE CUTLASS SUPREME S 1992
                OLDSMOBILE CUTLASS SUPREME SL 1991
                PONTIAC GRAND PRIX (1989 - 1993)
                PONTIAC GRAND PRIX GT (1991 - 1993)
                PONTIAC GRAND PRIX LE (1989 - 1993)
                PONTIAC GRAND PRIX MCLAREN 1990
                PONTIAC GRAND PRIX SE (1989 - 1992)
                PONTIAC GRAND PRIX STE (1990 - 1993)
                And we all know, any W body that got a manual that didn't have a 284 was a 282 (which would account for the 89-90 GPs) since the 284 was only used from 91-93 (in the Z34, GTP, STE and Cutty INTL.).
                • HayesPerformance
                  • 783
                  You MUST remove the wieght that's on the flywheel though, Thats how the fiero guy's do it because the 3.4 DOHC is internally balanced.
                  I wouldn't go with that light wieght flywheel if your using it in a w-body because of the wieght of the car VS. the power output, unless you have a lot of power, otherwise you will regret it after. I've seen it first hand.
                  If your building a turbo 3.4 DOHC and have the power, great!
                  1991 Grand Prix STE
                  3.4 DOHC
                  1 of 792 Produced
                  Extensive Mods Done
                  1991 Lumina Z34
                  3.4 DOHC
                  Getrag 284 5spd
                  1 of 30
                  • HayesPerformance
                    • 783
                    Or Lighten your car a lot......
                    1991 Grand Prix STE
                    3.4 DOHC
                    1 of 792 Produced
                    Extensive Mods Done
                    1991 Lumina Z34
                    3.4 DOHC
                    Getrag 284 5spd
                    1 of 30
                      that heavy ass flywheel makes for easy launches in the G6(but the super low 1st helps too). all 1st gen and 1.5 gen Ws are lighter than the G6 (IIRC), but some of the Gen 2/3 are heavier.
                      • 94GPGTP
                        95 Grand Prix GTP
                        • Apr 2007
                        • 593
                        i will try to bold my spare 282 pressure plate to my 284 flywheel.. if it does then the lightweight 282 fylwheel will work on the 284..
                        Robert
                        New Rebuilt 3100
                        New Rebuilt 4T60-E
                        Exhaust
                        White
                        5 Speed Swapped
                        127,000
                        Spec Stage 3 Clutch
                        Emissions Deleted
                        • 94GPGTP
                          95 Grand Prix GTP
                          • Apr 2007
                          • 593
                          Ok so heres my input.. The 282 Pressure plate bolts to the 284 Flywheel.. So therefor the flywheels are the same.. But... Now with the Fidenza Lightweight it has a removeable insert.. The clutch disc for the 282 is smaller than the 284 and the 284 uses more of the flyweel than the 282.. So is the insert for the lightweight big enough? i see that the wear marks on the 284 flywheel are pretty close to the edge where the bolts are for the pressure plate and since the 282 disc is smaller its further away from the bolts for the pressure plate.. Thats y im thinking possibly the insert might not be big enough.. Heres some pictures..
                          Robert
                          New Rebuilt 3100
                          New Rebuilt 4T60-E
                          Exhaust
                          White
                          5 Speed Swapped
                          127,000
                          Spec Stage 3 Clutch
                          Emissions Deleted
                          • 94GPGTP
                            95 Grand Prix GTP
                            • Apr 2007
                            • 593
                            I would like to also add.. All these Fiero guys are using 282's not 284's so the Fidenza is avaiable for them to use on the 282.. There has to be a reason why they dont make it for the 284 and even so the flywheels are the same why is it not listed with the 282 vehicles then??..
                            Robert
                            New Rebuilt 3100
                            New Rebuilt 4T60-E
                            Exhaust
                            White
                            5 Speed Swapped
                            127,000
                            Spec Stage 3 Clutch
                            Emissions Deleted
                            • no_doz
                              • Sep 2005
                              • 912
                              ive heard a bit about the fidanza flywheels shearing off & slicing through the trans casing/flying out-not sure if its true but thats enough for me to stay away!
                              also if you havent watched this video-its great info
                              http://60degreev6.com/forum/f103/fid...terials-t44319
