My brother and I did a 3400 and 5 speed swap on his 89 z24 convertible. The trans is out of a 92 z24. We put an autozone clutch in it to get him by and it lasted for a while, but would grind once in a while going into gear like it wasn't fully disengaging. So, we clocked the forks one tooth more this time and it was great.. Except 3rd gear. It wouldn't grab third very good. Lastnight on his way home from class, he was shifting from fourth into fifth and the shifter went over to the left- the 1st and 2nd shift gate area and stayed in neutral. And it's locked in that area. It can be moved in or out of the car(under the hood). We trailered it home lastnight and are just trying to figure out what happened. We've never heard of this happening before.
5 speed locked up
pop the shift cable ends off the arms on the trans and have him move the shifter around.. i bet you have a bad cable.
the 3rd gear thing is normal, the 3rd syncro is crap in HM282/NVG trannies.
if the cables turn out to be ok, the 3rd thing isn't normal at all..
according to his Myspace, Flint.Originally posted by 1988GTU View PostWhere in MI are ya's pb and bb?
If you read the first line of the first post, they are brothersOriginally posted by robertisaar View PostWTF? there is a pbeck AND a bbeck?
that's a reading fail on my part.... but he did fail to mention that they had damn near identical screen names. threw me for a loop.Originally posted by pocket-rocket View PostIf you read the first line of the first post, they are brothers
