Need 4T65E swap info
  • Joelfke
    • Mar 2010
    • 46
    Question : Need 4T65E swap info
    Hello,
    I am new here, but not so new to cars. I have an 04 Chevy Monte Carlo with a 3.4L and a 4T65E trans. The trans is slipping and banging into gear and the 1811 max adapt shift code is permanently set. There are multiple problems with the trans. I am not nearly experienced enough to overhaul it, so I would like to swap it. I have pictures of the ID tag on the trans but is there somewhere that has info as to what the numbers/letters all mean so I can match up a boneyard trans to swap in without problems? I can post pics of the tag if needed.
    Thanks for the help
    • 9191
    Welcome!
    • Joelfke
      • Mar 2010
      • 46
      so you only need the model year or compatible model years, and the broadcast code to match?
      • Joelfke
        • Mar 2010
        • 46
        is there a way to tell final drive ration from the trans tag?
          • 9191
          Find the broadcast code on the take and then look it up in one of the tables in the link above. That's the only way.
          • Joelfke
            • Mar 2010
            • 46
            ohhh!!! ok thanks i didnt understand what you meant at first. thanks for the clarification!
