Drive Shaft Question
  • eckoxl
    • Jul 2009
    • 230
    Question : Drive Shaft Question
    I have bought replacement driveshafts, everything is the same except the end that goes into the transmission.
    Is there a way to get that end out or do I buy new ones??
    Thanks in advance
    1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
  • eckoxl
    • Jul 2009
    • 230
    Solved.
