manual trans flywheels + 3x00
  • patgizz
    The Plaid Bandit
    • 1071
    couple short questions.
    do the hm282 and 284 trans use the same flywheel?
    will the crank of my 3400 accept an off the shelf pilot bushing? if so which one?
  • jmgtp
    • 1219
    Neither trans uses a pilot bushing, so no worries there. I *think* the flywheels are different but I do not know that one for sure. Perhaps the difference is in the bolt pattern for the pressure plate?
    1994 Corvette
    LT1/ZF6
    2006 Dodge Dakota 4x4
    3.7/42RLE
    • brian89gp
      • 554
      I'm pretty sure that all neutral balance 60v6 flywheels are the same.
        • 13533
        You can use the same aftermarket aluminum flywheels so the stockers must be compatible as well.
        • patgizz
          The Plaid Bandit
          • 1071
          sweet.
