How to remove shafts from NVG t550?
  • Barry
    95 Beretta LG8 Action
    • Aug 2007
    • 269
    Question : How to remove shafts from NVG t550?
    Heres where I am at. How do I remove the shafts from the trans? Theres no bolts there like there is on the getrags...
    95 Beretta- Lg8 Daily Driver
  • Barry
    • Aug 2007
    • 269
    For everyone elses sake and to get the info out there:
    Those caps are a 12 point 12mm internal hex. BUT you can use a standard 12 mm allen to remove them. Left shaft turns to the left and the right turns to the right just like a getrag. After that you need a press. I was not reusing the bearings so I used a torch and hammer instead.
