shift linkage. cable delete
  • Purple pit
    • Oct 2012
    • 718
    Who?
    It would be kind of cool to have a new "Beretta" cable on a Beretta. Also you can get a rise out of people with it.
    New shift cable?
    Yeah.
    Where did you get it?
    It's a Beretta cable.
    Yeah I know that.
    And so on.
    Grand Prix trans with 3.33FDR
      I did a thread on this on Bnet but no one was interested enough to deal with it or could afford anything so I dropped it.
      Push-pull cable manufacturer offering custom cable assemblies, hydraulic controls, and wire rope systems with global shipping.
      http://metrocustomcables.com/
      Custom mechanical control cables, push-pull assemblies, throttle, PTO, valve, brake, and replacement cables built for OEM and specialty equipment.
      And that is a cheap google search...
      • Purple pit
        • Oct 2012
        • 718
        Wow only one company from the US!
        Cracks me up how the auto trans guys do more searching that the 5sp guys.
        • Guest
          I thought about doing this years ago, when I had my Cavaliers and V6 Skyhawk. In the end I decided that it would be too difficult to get an accurate shifting linkage, with the route it would need to take. Hondas and other vehicles can use solid linkage because the transmissions are designed in such a way to make a linkage possible.
          I believe that the design of the transmission and the layout of the cables both contribute to difficult shifting. If the cables were solely to blame for difficult shifting then other vehicles that use cables would have the same issues and most that I have driven don't.
          • Alxsmt
            that one guy
            • Feb 2007
            • 725
            how exactly do you adjust it? if you loosen the linkage on the trans you might have 1/16" of play.. seems like I remember doing it on my old fiero at the shifter assembly in the car using some sort of pin to center it. never saw anything like that for the beretta.
            I have thought about custom cables, im getting used to the one-off parts lol. I have yet to price them but at $80 for the cheap one time use cables im kinda scared to price that.. just with my cable luck in general im scared they would fail on top of that. I have been using jy cables with a short shifter I made (less leverage) and that has helped this set last a lot longer that normal, at least prevents it from 100% failure where you cant physically move the shifter lol.
            yeah the design is definitely different for the trans. my geo has such a great design! so simple. shift linkage is on the bottom of the trans, 2 almost straight bars going to the shift lever in the car.
              I'm guessing that a custom setup would come with some sort of warranty behind it if they believe in their products... It's not cheap to play with the big boys...
              • Alxsmt
                that one guy
                • Feb 2007
                • 725
                #22
                hmm.. well I emailed a few companys to see whats involved. yeah it sucks in the $$ aspect lol
                • ericjon262
                  build it.
                  • Jan 2010
                  • 2218
                  #23
                  I've been working out the kinks of a hydraulic shifter for my fiero, probably won't ever do it, but if you want positive shift feel, hydraulic would be tight!
                  I'm leaving this link here for future reference...
                  • woody90gtz
                    3400/5spd Beretta
                    • Oct 2006
                    • 83
                    #24
                    Subscribed for news. My cables have always shifted really nicely, but a backup plan would always be a good thing.
                    91 SS . 3400/5spd - S&S, TCE, EP, FFP, SPEC, DSS, K&N . GEARHEAD dezign
                    • ericjon262
                      build it.
                      • Jan 2010
                      • 2218
                      #25
                      it'll be a long while before I start working on something like it, all I'm really doing right now is spitballing and research.
                      • Alxsmt
                        that one guy
                        • Feb 2007
                        • 725
                        #26
                        nobody I emailed replied lol.
                        that hydo idea seems pretty good!! hmmm.. so basically you would have a cylinder on the trans and the shifter right? well 2 on each
                        • ericjon262
                          build it.
                          • Jan 2010
                          • 2218
                          #27
                          they would need to be double action cylinders, but yeah, that's the basic idea.
                          • ga2001532
                            • Feb 2011
                            • 158
                            #28
                            I like this idea, I think I have something that may work
