Since I have never completed the MGB, I am not sure anymore if I can use the FWD flywheel with the camaro clutch or if I have to use the FWD clutch. Looks like its the same clutch, so does it matter?
RWD clutch with FWD flywheel?
Tags: None
It's the same clutch. The pressure plates are different but have the same bolt pattern. RWD pressure plates have the fingers stick out farther. I'm not certain but I think some of the RWD pressure plates may be different from others as well.'89 Firebird, 3500 Turbo, T56, 9-bolt/4.11
'86 Fiero, 3500, 4-speed
The 3.4 flywheel was really deep compared to the FWD. Would I have to be certain its a RWD pressure plate and any clutch?Ben
The 3.4 RWD flywheel has the same pressure plate bolt pattern as the FWD flywheels. For the S10 3.1 swap we used a FWD flywheel with an S10 2.5 T5 bellhousing, the 3.1 clutch disc, and a brand new S10 2.5/2.8 pressure plate (same part #).'89 Firebird, 3500 Turbo, T56, 9-bolt/4.11
