I have a 2003 Impala with the 3.4L LA1 V6. Naturally, it has the autotragic transmission. I have discovered that the GM F40 six speed manual can (in theory) bolt into this engine. Naturally, I would love to do that. The question is, would this be something that would be actually possible to do? Does anyone see any immediate problems with this?
2003 Impala...maybe with a manual?
Tags: None
immediate problems will be your skill or your wallet. Can you weld/design trans mounts? Can you pay someone to do this for you? Do you have access to HP tuners?14.63@92.9 -Full LX9 with CAI, 65MM TB, 2.5in DP, Borla Cat-Back, Crappy tires, Quick tune (Dyno Soon)
It can be done I've been looking into it for a while now I have a 98 grand prix se3100 im collecting the part I need still need the f40 and a n body subframe its doable but like younggun said its hard and expensive af I've been looking for a spare w body so I can mock it up on there then swap it all over then I would only need to do the pedals, shifter and well all the ecu mapping
