4T60-E Gear Change ?
  • Zfreak
    • Nov 2004
    • 23
    Does anyone have any experience with changing the Gear Ratios in the 4T60-E Trans? Can it be done ?
  • napatiger
    • 490
    Yeah, what he said, but with some pics.
    From what I heard you have to get some parts off a 4t60e with the 3.1 engine b/c that trans had bigger? gear ratio, something to do with the sun gear and other sh...
    95 MC Z34 Black
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      The gearbox ratios never changed. But you can change the drive chain ratio or the final drive ratio.
      • Zfreak
        • Nov 2004
        • 23
        Ok so how does someone go about changing the chain or final drive?
        Where to get parts?
        • ko0t3rskkar
          • 39
          Swap the diff. from another tranny.
          1989 Chevy Corsica LTZ
          2.8L 60° v6
          5 speed
          • JJ77
            • Oct 2004
            • 112
            Speaking of changing gears I found this on an old forum and was wondering if it was B/S or True
            4T60-E comes with a 3.06 carrier with 33/37 final drive gears that equal out to be 3.43 (same idea as a rear end) if u change the carrier to the biggest one that was avaliable which is a 3.33 instead of a 3.06 and with the 33/37 u end up with 3.73's I know it sounds funny but it works. Second a shift kit from Transtar, just some minor valvebody work and the prize piece, a nice torque converter I use Protech converters they got me a nice converter with a 2950 stall which is perfect cuz we all know with the 3.4 it pulls at 4k. i ran 16.60's now i run 15.00's all u v8 mustangs watch out im huntin u hope i help anyone looks to pick up on ur 1/4 time
            1991 Lumina Z34 - http://members.sounddomain.com/lcmbear77
            1979 El camino (Faster of the two)
            FFP Stuff (chip, D Bone, UD pulley)
            Custom STB,WAI with K&N, Full Catback with Dual Magnaflows and Rative tips, 3k stall and 3.73 gearing coming soon
              • 9191
              • firechiken
                • Feb 2004
                • 557
                Any pics of the chain sprockets? I'm assuming that if you could have a chain made to fit you could use any combo of those sprokets, ie 28/37? What does that work out to? I have a book at work that I use to figure this stuff out, but I won't be there until sat.
                • JJ77
                  • Oct 2004
                  • 112
                  ooohh
