440t4 3.73 upgrade?
  • SS_EURO
    • May 2005
    • 74
    440t4 3.73 upgrade?
    Is this an upgrade that makes a difference worth doing?I'm looking in to it but I don't know if it's all that.What are the parts and cost.can I order new insted of getting these peices from a donnor?
    I\'d rather push a CHEVY than drive a Ford!
    • 13533
    RE: 440t4 3.73 upgrade?
    Ive heard it makes a better difference on the pushrods than the DOHC, but I have no experience with the DOHC in that config. Id say its worth doing if you don't mind a gas milage hit. The pushrods I am referring to hearing comments on are all gen 3 motors, not gen 2.
    • SS_EURO
      • May 2005
      • 74
      first i have to get the car running with new cam. Then I'll see the mileage.How bad is the mileage decrease? do you think i could get a different vac mod to help the shifts a bit i heard b&m has one?
      • SS_EURO
        • May 2005
        • 74
        Well i guess no ones done this yet. I need to find a dscr does any one have one
        • SS_EURO
          • May 2005
          • 74
          my bad I need a dscr from a cww 3.4 tdc. Anyone?
          • maybe2fast
            • May 2004
            • 16
            I have a Reatta and it has 2.97 FDR, it has the 440t4 and I would like to swap it over to the 3.73. What do I need
            1990 Lumina 4dr. Euro 3.1 White
            • maybe2fast
              • May 2004
              • 16
              anyone?
                • 9191
                Guess no one wants to help you. Let me find some of my old 440T4 manuals and see if I can find any information for you. I think really the only differences between the 440T4 and 4T60E, as far as changing the ratios, might be the diff ratio and the chain/sprocket setups. I'd think everything else should be basically the exact same.
                I haven't messed with either tranny, and I haven't read through they 4T60E how-to in a long time, but if I can find some info, it might at least get you headed in the right direction.
                • z284pwr
                  • 88
                  Hey Brad, I don't suppose your 440T4 manual have any sections about performance tips do they? The manual we have just mentioned a basic rebuild.
                  Anyways, for the topic at hand, what other info are you looking for, I have the 440T4 manual here handy and can look up any info you need, perhaps trans numbers that would have your gear upgrade or what not?
                  Brian Edwards
                  '73 Trans-Am
                  '79 Suburban
                  '90 Beretta INDY
                  '90 Turbo Grand Prix
                  '04 TSX
                  '04 TL
                  • gpse3400
                    • 1460
                    If your set up is a 2.8/3.1 and it is mated in a W car then you'll need the drive chain sprokets from a 3.4 tdc 4t60e transmission. that will give you the 3.73 ratio.
                    Lorenzo
                    • napatiger
                      • 490
                      I was about to scrap my 60-E b/c I cracked the case.
                      I pulled the pan for me, but if you need gears, let me know quick.
                      I know nothing bout the tranny but if you explain how... I can prolly pull it.
                      95 MC Z34 Black
