5 speed speedo 15% off?
  • Calvin
    3.77 1st gear sucks...
    • Feb 2006
    • 61
    On the highway yesterday I couldn't help but notice that my speedometer now seems to be about 15% off after swapping transmissions.
    I put an 88 W 5 speed in place of an 89 W 5 speed, did the speedo gear part number change or something? I left the VSS from the 88 trans in, and never swapped anything? Driving with the pace of traffic is still the same RPM (2800-3000) so the gearing is the same. I am confused...
    • 13534
    The RPM isn't going to change as thats based off the engine. The speedo is based off the transmission, which has a different VSS setup. You need to either swap the part out of the old trans or reprogram the computer for the new VSS setup.
    • sharkey
      • Jun 2004
      • 2061
      just grab the speedo off the old trans and throw it in.
