01 3400 Dyno chart
    01 3400 Dyno chart
    Does this HP output seem low to anyone??
    This is a 01 3400 that I built for my beretta, they dyno chart has a few runs in there with a 75 shot and then 100 shot of nitrous, so really only pay attention the the 3 lowest runs.
    These were all done with a stock 4t60e, 2.97 gearing, with a 1650 stall converter and rather heavy 16" wheels, approx 50-55lbs each.
    Reason I'm asking is because this car will only do a 15.6 at best n/a and thats after changing to 3.33 gearing and a 2060 stall and way lighter rims.
    I'm thinking I did something wrong and its not putting out the power it should be. It seems quite flat after 5200 on the street.
    • 9191
    If you are running the stock 95 PCM, then I'd say that's your restriction right there.
    • onefastV6
      • Sep 2005
      • 880
      Not sure what all is done to your engine, but my 01 Grand Am with the 4T45e put down 143.2 HP with the only mod being a borla catback.
      2000 Grand Am GT
      2011 Chevy Impala
        Yeah I forgot to list mods, but they mods are FFP Underdrive pully, Tranzgenic cold air intake(doesnt really apply to a dyno run) 2 1/2 downpipe and 2 1/4 exhaust, hollow cat, Mororso spiral muffler and a Flowmaster 80 series. All poly motor mounts, minus the tranny mount, 99 3400 injectors, and at that time i was running the 55psi FPR.
        My 95 3100 with a 3400 top end put down 150hp with 150 torque, and that was with approx 160k on the lower end.
        So with my motor swap I lost approx 6hp, and gained only 18ftlbs of torque.
        I am working on eliminating the 95 ECM I know that hurts a lot, but I'm just lost because in its current state the car will only do a 15.6 at best, and a friend with a Z26 with a 04 3400, same bolt ons minus his exhaust is a borla bullet, and a cat but a 2" intermittent pipe, and Stock trans/converter and he was able to pull a 14.96 with only removing interior, seats, carpet and spare tire.
        I'm not sure if the 01 vs a 04 3400 may have less power.
          • 13534
          How is your 3100 putting 150 to the ground? Mods?
          • torq455
            If I only had money!!!
            • 1615
            Don't forget about different axle/gear ratios ya'll. Same engine with the different tranny will give you different dyno #'s and track times.
            Andy
            fastest 1/8: 10.19@ 67.17
            fastest 1/4: 16.16@ 82.70
              I don't know. It was all the same mods as what I have now, with a 2" down pipe, stock 3100 manifolds, and it was a 3100 with a 3400 top end, intakes only. Oh and only a WAI
              I now have a full 3400 .030 over so its not even the same block or anything.
              I have the dyno chart if you want a scan.
              My first ever dyno with the 3100 stock, was 123, my second one with the 3400 top end like 20k later was 150, 152 And I dont think he caught that on peak either.
              • torq455
                • 1615
                MOD--LSD from who and how much?
                Andy
                  EP I paid 499 during the winter.
                  www.engineered.net Talk to Jeff and tell him Jon Chmura sent ya
