Cam position sensor
  • 19Cutlass94
    • Apr 2005
    • 770
    Cam position sensor
    Im trying to figure this out, the cam position sensor on the '04 3400 is different than the '94 3100... both are 3 wire sensors. Its it possible to swap the two sensors, as in put the '94 3100 in the '04 3400 or will I have to splice wires to get them to work?
    Thanks for any help and hopefully you guys can know what Im trying to ask lol
    3400/Getrag 284 5spd
    350/NV3500 5spd
    2014 Chevrolet Malibu LS
  • loner666
    • Oct 2006
    • 435
    you can put the '94 sensor in it no problem..thats what i did with my '03 3400 and havent had a problem
    Best 1/4mile ET - 12.9
    Best 1/4mile MPH - 111
    1997 Ford Ranger Splash
    Daily Driver
    • 19Cutlass94
      • Apr 2005
      • 770
      Cool. Thanks!
      350/NV3500 5spd
      • loner666
        • Oct 2006
        • 435
        no problem
        Daily Driver
          Hell I'm using a 05 3500 sensor on my MMS stage 1 cam, in my 04 block in my 95 car with a 96 beretta harness and 97 venture ecm............
          Yeah I spliced in the new 04-05 connector to my harness
          This is why I call my car a mutt...
            Any sensor will work is the general belief now.
            • geldartb
              The Situation
              • May 2004
              • 1994
              im using an 05 sensor in the 05 engine on my 99 grand am. jon actually did the soldering.
              if your good at splicing the wires just use the one thats in the block now.
              99 Grand Am GT
              1357 cam 227 233 .050 dur
              515 515 lift 112 lsa
              • 19Cutlass94
                • Apr 2005
                • 770
                I mean if the sensor that I have right now in my 3100 will fit, I figure I can use that cause it will be much easier to put in and Ill just have to plug it in and not solder anything. If it comes down to it I guess Ill have to solder it, but two of the three wires are different color so Id have to find out which ones to solder them onto haha
                350/NV3500 5spd
                • geldartb
                  The Situation
                  • May 2004
                  • 1994
                  yeah it will fit same hole.
                  99 Grand Am GT
                  • 3100 MPFI
                    • 1522
                    I think there is a difference in the cam ring. I know when we sent in 2 cams for regrinds, my 1999 3100 cam had a tab sticking up, but the 2000 3400 cam had a solid ring with a notch in it.
                    I didn't think they could be interchanged (using the newer 3400 cam and get it to work with the older setup). I thought if you had a 1996 and a 2002 3400 then you had to use the 1996 cam, and sensor.
                    Taylor
                    1998 Lincoln Mark VIII
                      • 9191
                      This has been discussed several times and argued a ton. There are now 3 different cam trigger patterns, but all of them operate in the same manner (leading edge change). Therefore, all the sensors will still create a square wave that always changes the same, although the actual waveform may be slightly different. The PCM is looking for the change though, so any sensor should work with any cam.
                        Yup it all works so far no one has had a combo that didn't work.
                          • 13534
                          Well that is good to know. I think our cam article says otherwise...
                            well I have a milzy cam in a 96 setup... well 97 setup. thats tooth design to the ring with a notch... I've had no problems.
