mrz udp
    I had one on the 3500 and didn't have any problems.. oh wait...... never mind
    If someone had the propper setup to vulcanize a strip of rubber in a UDP then we'd be set. FFP posted an 11 HP gain dyno sheet with theirs.
    • 19Cutlass94
      • Apr 2005
      • 770
      #32
      Originally posted by andrew383 View Post
      i had to swap the ring on my mrz udp. has any one swapped one over? or wound the 3400 one work??
      The 3400 and 3100 timing ring is the same.
      3400/Getrag 284 5spd
      350/NV3500 5spd
      2014 Chevrolet Malibu LS
      • andrew383
        • Nov 2007
        • 70
        #33
        ffp went out of business i think. theres doesnt have the rubber either http://www.v6z24.com/howto/pulley
        sigpic03' 3100 slp cat back-custom fwi-gmpp trailing arms-mrz udp-aeroforce
        • andrew383
          • Nov 2007
          • 70
          #34
          the asp one looks to be bolt on,not pressed on. is that right?http://www.aspracing.com/frame.htm
          • 19Cutlass94
            • Apr 2005
            • 770
            #35
            Thats the ASP pulley you would want if your putting one on.
            and what do you mean bolt on, pressed on? Its the same EXACT thing as the FFP/mrz. The bolt at the end of the crank pressed the crank pulley/UDP/harmonic balancer on.
            350/NV3500 5spd
            • andrew383
              • Nov 2007
              • 70
              #36
              https://www.aspracing.com/ezRetail/s...php?msg_id=145
              is that the pulley you have?the 3.4 pulleys i saw didnt press on like the one you have a pic of. does it have the rubber in it? doesnt look like it
              • geoffinbc
                Iron Head Enthusiast
                • 5831
                #37
                Are you talking 3400, 3.4L DOHC or 3.4L GenI (Iron Heads)
                The 3.4L Gen I motor just has a simple bolt on pulley. The damper sits behind the pulley. In this case you can go to any size pulley without affecting the harmonic damper.
                • andrew383
                  • Nov 2007
                  • 70
                  #38
                  ya thats the one i saw,but not the one i need
                  • 19Cutlass94
                    • Apr 2005
                    • 770
                    #39
                    what one do you need? What motor?
                    350/NV3500 5spd
                    • andrew383
                      • Nov 2007
                      • 70
                      #40
                      the one like you posted in post 36
                      • 19Cutlass94
                        • Apr 2005
                        • 770
                        #41
                        ohh, well the link is there, all you need to do is transfer the iginition ring, and bolt it on. and get a smaller belt.
                        350/NV3500 5spd
                        • andrew383
                          • Nov 2007
                          • 70
                          #42
                          does it have the rubber in it? is it the same one you have?
                          • 19Cutlass94
                            • Apr 2005
                            • 770
                            #43
                            All UDP's dont have any rubber in them. They are NOT harmonic balancers. Yes its the same pulley that I have.
                            350/NV3500 5spd
                            • andrew383
                              • Nov 2007
                              • 70
                              #44
                              the ones that have the rubber are balancers tho rite??
                              • 19Cutlass94
                                • Apr 2005
                                • 770
                                #45
                                In the picture I posted with the two side by side, The black pulley was the Harmonic Balancer, which has the rubber in it. the smaller silver pulley was the UDP which does NOT have any rubber in it.
                                350/NV3500 5spd
