engine siezed up!
  • Jbrogan
    • Oct 2006
    • 203
    engine siezed up!
    i just got done putting my turbo on and was driving it home. the car stalled and now it is siezed up. i looked and the oil filter fell off, so it was running for at the most 5-10min withe no oil. i was just wondereing what is the usual parts that go bad and if i should try and keep er goin if i should keep
    1996 Beretta
    3100 SFI TURBO
    13.1 @ 103 mph best in the 1/4 mile
    cam bearings, rod bearings, main bearings, crank, cam, rods, possibly the oil pump.. maybe even more.
    time to find another engine, that one is toast... sorry
      Wait, you have a turbo on there all of a sudden? Pics! What are you doing to tune for it?
      I'd just grab a full 3400 for cheap from a junkyard with less miles. Probably end up cheaper and you have a bigger/better engine to start from.
      • loner666
        • Oct 2006
        • 435
        that sucks man. Time to get a 3400 in there. Alot better plattform to start with. Just beware of the trans not holding up. I dunno on a stock 3400 but with mine the trans arent staying happy long
        I was going to do a basic tune for him to get him going safely
        Best 1/4mile ET - 12.9
        Best 1/4mile MPH - 111
        1997 Ford Ranger Splash
        Daily Driver
        • sprucegagt
          Old School KI
          • May 2005
          • 703
          How the hell does an oil filter just "fall off?"
          Your local OBDII moderator
          2000 Grand Am GT w/ WOT parts
          • 1988GTU
            LB62LHObbqftmfw
            • Nov 2005
            • 2475
            New engine time! Maybe go 3500?
            Engine Gremlins.
            • john_V63400
              Banned
              • Feb 2006
              • 409
              sorry to hear that man, once my oil line poped off my S/C on my Grand Am and I ran dangerously low. Luckily I was in town in stop and go, and heard my engine starting to knock, I about shitted my pants. I dont mind blowin em up from fun, but dang simple mistakes like that sucks. More like accidents! good luck man!!! It happens. Luckily I caught it
              • Jbrogan
                • Oct 2006
                • 203
                well guys i took off the oil pan and the conecting rod bearing at waht you would call the front off the engine welded itself to the crank. so i took 1000 grit sand paper and sand the journal until there was no more rod bearing stuck to it. then i replaced all of the connecting rod bearings to be safe. now before it seized it didnt even knock at all so that tells me that none of the bearings actually spun. i checked all of the journals and they all were smooth with no signs of wear. so we will see how long it lasts. im considering it lucky to have gotten this far. but the turbo is toasted. oil poors out the exhaust until the turbo spools and then it will quit so iu gotta get another t25 or rebuild it.
                1996 Beretta
                3100 SFI TURBO
                • Jbrogan
                  • Oct 2006
                  • 203
                  these are the pis i took when i was mocking it up, i will show updates soon.
                  1996 Beretta
                  3100 SFI TURBO
                    Live life 3.7mi at a time
                    • 4555
                    That looks similar to Loner's, lol, but he has the BMW headlights that made the pipe routes tight (and he didn't want to 86 the washer tank )
                    • loner666
                      • Oct 2006
                      • 435
                      i didnt want to but that still havent put it back in..im gonna redo some more the of the piping when i change my headlights so maybe ill be able to put it back in
                      Jbrogan took my idea when the pipe routing..lol
                      Daily Driver
                      • 3.1cutlass
                        • Feb 2007
                        • 101
                        dude how did i not know about this? sweet. I need to see this soon!
                          • 4555
                          LOL, at first glance that looks like it could be your engine, even. Just needs a colored fuel rail.
                            Wow, you've been busy. Do you post on any other boards like the beretta boards? Got rid of ABS I see. Odd placement of the turbo, how does the downpipe route? Go for a larger turbo if you can, the T25 isn't that great for the 3100.
                            • 1988GTU
                              LB62LHObbqftmfw
                              • Nov 2005
                              • 2475
                              I think you should just route the down pipe in front sticking through the middle of the bumper. When people ask about the pipe, tell them it's your waste pipe.
