A tail pipe in the front bumper? LOL
engine siezed up!
LOL that's not gonna be street legal. That's kind of ugly, I'd just shoot it out somewhere under and aim it to the side.sigpic
Interesting......even though you sanded off the bearing material on the journal it maybe out of round......then again you may get lucky....I hope you do so we can see the numbers!2004 Black Cobra Vert
New Best Time 9-2-07: 1.81 60' 12.06 @ 117.3 Mph
455 rwhp/ 458 rwtq
1988 Pontiac Grand Prix SE - New Setup: Stock 3400 with 52 k on it from a 05 Impala, 255 walbro, LC-1 WB, Spec 3 Clutch, CS144 Alternator upgrade, DIY tune
1989 Pontiac Turbo Grand prix - 44 k original miles, birchtrax'ed & intrax'ed, crane 2020, Topgun 160 +++ my own special herbs and spices
the stock tb size on a 3800 supercharged is 69mm. i had 2 eaton superchargers with tb, so i took the butterfly out of one and bored out my 3400 tb, so it would be 69mm.
1996 Beretta
3100 SFI TURBO
13.1 @ 103 mph best in the 1/4 mile
Are you sure about that? I had a 3400 TB bored out to 65mm with a 62mm I.D. sleeve as the part where you clamp the air tube too was no more after boring on the small parts.sigpic
idk i just looked it up and it said on some site that 3800 tb was 69mm, maybe not idk.
1996 Beretta
3100 SFI TURBO
Yeah s/c 3800 are 69mm. Wow, pics of the TB?? it has to be sleeved to be bored that much!! wow!
3.1cutlass: so he got it running again? I guess the crank/etc came out ok?sigpic
Ya it is running good. Idles like crap because he i running the stock tune right now. I saw him keep up with a 13 second ls1 camaro in it.
Does he have a FMU at least then?? How much PSI? That turbo is pretty small too.sigpic
garrett t25, it has boost creep bad though because the internal wasgate is too small. 7-8 psi in first, 9-10 in second, and 10-11 in third. its running about a 14.0- 14.1 right now and it starts losing power in second and third. im hoping the tune fixes it.
1996 Beretta
3100 SFI TURBO
