hey everyone.
my 3.4/3400 hybrid is having issues. i went to do what brad did and put the 2000+ 3x00 intake on with the 1996 3100 heads i had on the motor, seeing as how my ported 2000+ 3x00 heads werent done yet.
i also "pulled a brad" -- forgot the article was on this site, and managed to collapse 4 lifters... and then some, bent 4 pushrods, and a VALVE! well after spending two weeks trying to figure out the car, and then taking the car and shoving it on a mechanic who i am sure fucked it up for me so id have ot bring it back and pay him more money (just cant figure out wtf he did to my car) -- im at this point :
car runs ok. when i step on the gas i get stumble/misfire..like... sounds like small detonations happening inside the engine. knock sensor on Auto X-ray reads max of 6 - not showing any knock retard.
trying to figure out why this would happen..the plenum is pretty close to the cowl - in the f-body the engine sits 1/3 under the cowl (stupid GM) so i managed to get it under there, with 1/8th inch clearance between the 3400 plenum and the cowl. not very much to work with, but hte car runs like i said.
my concern is, wtf is wrong with my car. i cant go wot from a stop or the car stalls, if i step on the gas more than 50% while accelerating it stumbles..feels like its gonna stall or something..detonation i guess -- not sure. i havent checked my ign module but havent had a reason to unless one of you says i should...
i dunno on this one -- im fresh outta ideas. i AM running the stock 3.4 RWD program which includes like max of 60* of spark advance while cruising (max that i saw on auto x-ray couple of weeks ago)
i've talked to ben but thought i would ask aorund... i did try putting a ECM from a 1995 Monte Carlo into my car, it didnt help the problem one bit. and my speedo stopped working (shrugs)
anyway...
any info / help would be appreciated.
anyway...
