gen 1 2.8 aftermarket heads
  • montess408
    • May 2006
    • 391
    i was reading this here a long time ago that there was aftermarket heads avalible for the
    2.8 iron head motor does anybody know what i am talking about or remember the name of them ??
    • 13522
    there were potter heads, and RFRE heads. Perhaps some others but as far as new castings that were aftermarket, that is what comes to mind.
    • montess408
      • May 2006
      • 391
      thanks ben !
      do you know where i could see pics of the heads or if there is a web site ??
        • 13522
        There isn't much info out there and I don't know where the pics are anymore. I was hoping someone else would say more on it.
          Live life 3.7mi at a time
          • 4555
          They are little more than myth. They were so obscure that only race boats and stadium trucks got them.
          You are better off doing a FWD head swap.
          The Potter heads were basically testing grounds for Gen2 heads
          • montess408
            • May 2006
            • 391
            so there is no chance to have a set available nowadayz then ?
              • 4555
              I have never seen a set, so I decided to use the Gen3 stuff on a 3.4. It should smoke some LT1 F-bodies after the mods
                • 9189
                Even if you found them, you'd need the matching custom intake manifold setup, as the heads are "complete". In other words, the intake manifold does not complete the top part of the head (like the regular heads). Its not like its just a plug-and-play modification.
                  • 9189
                  http://60degreev6.com/forum/showthre...ht=potter+boat
                  • geoffinbc
                    Iron Head Enthusiast
                    • 5831
                    I bet Gen III heads would blow them out of the water anyway.
                    • montess408
                      • May 2006
                      • 391
                      so there just a early try at the new aluminum heads of today then so not worth the efort to try to get a set
                        • 4555
                        Your biggest hurdle for the Gen3 heads on a Gen1 block is the DIS conversion (unless you get a 3.4).
