valve adj. please help
  • dean B
    • Mar 2004
    • 10
    I just replaced my head gasket on 97 MC3.1L,when I turn the key the engine didnt start.SO I backed off the valves and the engine fired up.Can any tell my if I bent a valve or push rod by tighting the valves too much?
    And is thier a valve adjustment for that year engine?
    Im having alot of valve train noise.
    THANKS
    just need head gasket info
  • dodgerunner
    • Mar 2004
    • 14
    Did you put the pushrods back in the right place.
    The exhaust and intake are different length.
    96 Intrepid, 95 Ram, 96 GP3100, 88FieroGT 85FieroGT3.4, 74Vet, 67Stang
      • 13533
      They are not adjustable, and should fire up even if you switch the pushrod locations. Mixing those up will kill a cam/lifter though. If your rocker arms bolts/nuts are loose, then you are going to get a lot of valvetrain noise. My guess is its a coincidence that it didnt fire up before and did after you messed with the rocker arms.
