93 3.4 rwd doesnt downshift all the time-tps?
  • no_doz
    • Sep 2005
    • 912
    in my 93 3.4 camaro with 4 speed auto-when i floor it in OD it doesnt drop a gear-doesnt act any different-full throttle in OD is just like half throttle-once i get to half/ 3/4 throttle it kinda stumbles from time to time-also the idle is a tad rough but im not throwing any codes-ideas?
    dont get my wrong this thing runs like a champ, but just cruising around town when i get on it-it acts goofy as stated above & i have no clues.
    I would check it, very well could be.
    • no_doz
      • Sep 2005
      • 912
      how do i check it?
        • 13520
        you have to tap into the wires and check voltage as the throttle as increased. Easier to use a scan tool but I don't know what a camaro would use for scanning. That or swap with another TPS and see what happens.
        • no_doz
          • Sep 2005
          • 912
          ahh ic-its probably not going to matter because as soon as i know everything im going to need for the 3400 top swap-im putting that stuff on & i assume that ill be using that TBI & TPS-but are you guys pretty sure that the TPS is whats causing this? in D if i put it to the floor it acts normal-but it wont upshift (unless i let off) until it damn near hits redline-in OD it works great with the exception of no downshifting at full throttle-also in D my gas mileage is 15 mpg no matter how i drive it but in OD its around 25-any ideas?
