fuel rails
  • hookdonspeed
    • Jun 2007
    • 322
    fuel rails
    just need to make sure of this before i goto the yard this weekend...
    the pre-00 and 00+ fuel rails are the same with injector size and all except the FPR correct? are the FPR's swappable?
  • geldartb
    The Situation
    • May 2004
    • 1994
    yep they are the same
    FPR is the same physical shape just different PSI
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
    • hookdonspeed
      • Jun 2007
      • 322
      injectors the same rating?
      • geldartb
        The Situation
        • May 2004
        • 1994
        the pre 00 injectors run on a psi of 43.5 flow 19lb/hr
        the 00+ ones run at a psi of 55 flow 22 lb/hr
        99 Grand Am GT
        • hookdonspeed
          • Jun 2007
          • 322
          they are the same i checked part numbers, the difference in lb/hr must be made in the FPR
            • 13530
            99 and older are multec 1 and 00+ are multec 2 so it can't be the same part number unless they give you an adapter for the electrical connector.
            • hookdonspeed
              • Jun 2007
              • 322
              99 gam 3.4 fj93
              02 impala 3.4 fj318
              04 malibu 3.5 fj649
              bah i did something wrong.,.. need more coffee
              i wish the 3.5 and 3.4 injectors were the same plug :/
              whats the 3500 injectors rated at?
                • 13530
                24# from what I have heard, but they are shorter than the 3400 injectors.
                • hookdonspeed
                  • Jun 2007
                  • 322
                  i think im just going to get a aftermarket FPR and changeover the car to returnless rather then swap the fuelrail to return style, sounds like itll be easyer *Sigh*
                    how is that easier?
                    Grab any 3x00 fuel rail, grab 6 injectors from a 3.4 DOHC (24lb/hr) and snag a FPR from a 99 or older 3x00 (43 PSI).
                    oh wait, aren't you using the whole OBD2 setup?
                    • hookdonspeed
                      • Jun 2007
                      • 322
                      yea, full odb2, need to modify the fuel lines either way, i was thinking i can just use the 3line 99vette fuel filter/regulator setup (constant 55psi) they have, run 1 line to the injector rail and the feed/return to the filter. then i wont have to worry about changing the wiring, or clearance on UIM for the FPR
