which gasket to get??
  • new_to_gm
    teh GM noob
    • Nov 2009
    • 4
    heya guys, im new here and to the field of GM's (note the screen name Lol) i've always been a nissan/ford guy but recently alot of people have been coming to me with problems with their 60* v6 GM cars. my latest one is a 97/98 cutty supreme SL with the 3100, needs new LIM gaskets (typical from what i've been reading) my question is, how do i tell which version of the 3100 this is without having to pull the top end apart just to check if it has the roller rockers or the solid/fixed rockers.
    the reason i ask is because i was calling around getting price checks and everyone asked me if it had roller rockers or solid mounts, at which point i confusedly looked at the phone and said "lemme check" and hung up LOL.
    as i understand it the roller rocker version has the pushrods coming through the lower intake or something like that (please correct me if im wrong, which i probably am) and the solid rocker version doesnt have that. all i know is that it makes a difference in the shape and price of the LIM gaskets..
    feel free to laugh at my lack of GM knowledge, i know my way around a 4.6L ford v8 and a nissan VG30ET better than i do with any chevy/GM motor.
    any help is greatly appreciated guys! thanks! =D
    im a total GM noob so bare with me on the stupidity factor. just for S&G's heres what i got
    1985 300zx NA (currently being restored:()
    1987 300zx NA (turbo swap coming soon!:p)
    Looking at a 1990 camaro RS 3100 auto, needs a new keyfob system. dont know about this one though.:huh:
    97 was the last year for the cutlass supreme, and it has the roller rockers, they all did starting in 96 IIRC...
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      Roller non stamped. Going to be small port.
      • new_to_gm
        teh GM noob
        • Nov 2009
        • 4
        awesome, thanks for the help, anything else i should know before diving into this tomorrow morning? Lol
        • 1988GTU
          LB62LHObbqftmfw
          • Nov 2005
          • 2475
          Change the distributor cap o-ring and properly torque it all to spec. Use the revised metal gaskets and not the plastic pieces of junk. Flush the coolant out and be sure to do a couple oil changes with good filters soon after assembly.
            • 13525
            Correct. Make sure you use the metal gaskets and put loctite on the lower intake manifold bolts. There is a revised torque procedure for the lower intake.
            Lower Intake Manifold
            Bolt - Center
            First Pass
            7 N·m
            62 lb in
            Final Pass
            13 N·m
            115 lb in
            Bolt - Corner
            First Pass
            13 N·m
            115 lb in
            Final Pass
            25 N·m
            18 lb ft
            • new_to_gm
              teh GM noob
              • Nov 2009
              • 4
              its got coil packs IIRC, could be wrong though.
              Bolt - Center
              First Pass
              7 N·m
              62 lb in
              Final Pass
              13 N·m
              115 lb in
              Bolt - Corner
              First Pass
              13 N·m
              115 lb in
              Final Pass
              25 N·m
              18 lb ft
              sweet, hanks for the numbers there. have to dig out my in/lb torque wrench
                • 9190
                It does have coil packs, but there is still an oil pump drive assembly where you would typically find the distributor. This gasket has a tendancy to leak, so its a good idea to replace it while you are in there.
                • new_to_gm
                  teh GM noob
                  • Nov 2009
                  • 4
                  ok cool im not loosing my mind then Lol. i will keep that in mind when i have it torn apart tomorrow. thanks a million guys! i realiy appreciate it
